03-08-2021
11:56
04:16
JuanJoFitbit
03-08-2021
11:56
04:16
JuanJoFitbit
I have a fitbit Aria 2 and the BMI is quite off. My Aria 2 shows my BMI at 34-34.4%, but if I put my weight and height in a BMI calculator it shows as 26.5%
The scale is on a hard flat surface and I weigh myself bare footed.
I've tried adjusting my profile gender, saving, then setting back and saving along with removing the batteries and weighing myself 5 times in a row as shown in another thread, but it still shows the same BMI.
I read that the Aria 2 uses bioelectrical impedance to calculate the BMI. Could sodium impact that? I keep myself on a low sodium diet vs the average person per my Dr of 10,000mg of sodium.
03-08-2021 12:20
03-08-2021 12:20
First, let's make sure what you are talking about. You say BMI (body mass index), but it sounds like you are talking about fat %. These are often confused but are totally different things.
BMI is a simple calculation from height and weight and is not a percent. Body fat % is the makeup of your weight.
Best Answer03-08-2021 12:20
03-08-2021 12:20
Best Answer03-08-2021 15:28
03-08-2021 15:28
You're totally correct. I've been misreading what that number is all along. Thanks for your help.
