07-28-2018
09:53
08:45
07-28-2018
09:53
08:45
My Aria 2 stops syncing randomly and the only thing that works is to redo the wifi setup, i.e. identify the network and reenter the password (for the Aria 2 device). Very annoying and frustrating.
Why is this still an issue? Obviously many users have complained over the past year. It's not like the scale is a cheap toy, so I would expect more from Fitbit.
Moderator edit: subject format
@MiMyself Welcome to our Fitbit forums! I'm sorry to hear that you need to repeat the setup process with your Aria 2 in order to fix the syncing issue. I want to follow up on this and would like to know if the issue persists or if you don't need to re-set up your scale so that it syncs your data properly.
I moved your post to the Aria 2 board in order to keep the Community organized.
See you later! ![]()
Have you moved the scale closer to the router?
one cruise ship at a time!My scale won’t reconnect to the network after installing a new router. I’ve tried moving it closer to the router as suggested with no luck. It finds the aria network but then says internet connection not available.
@NanaDonna Thank you for joining us in this thread and our Fitbit Community! Let me go ahead and find a solution for the setup issues you've experienced with your Aria scale. Please let me know if your scale shows any error message when trying to connect to your network. In the meantime, make sure that you are following the setup process as listed in this help article, including the router settings needed.
Looking forward to your response! ![]()
@NanaDonna Thank you for getting back! Please make sure that your new router complies with the settings that are needed to set up your Aria 2. The router settings are listed in this help article as well as the setup process.
Please let me know if the issue persists and I'll be happy to further assist you! ![]()
@Desposyni Welcome aboard to our Fitbit Community! I'm happy to assist you with your Aria 2 since it's not registering your data in the Fitbit app.
Please make sure that your phone has the most recent Fitbit app version installed. Also, let me know if your web-based Dashboard does show your data.
@pajill, I'm sorry for the late response. However, I would like to follow up on the syncing issues that your Aria 2 is experiencing.
I would like to know if you have made changes to your network such as router, WiFi password or WiFi settings.
In the meantime, try restarting your router. Also, restart your scale by taking out the batteries and putting them back in. After these steps, monitor your Aria 2 for the next 24 hours and see if the issue gets fixed.
Keep me posted on the outcome.
Best AnswerMy versa 2 wouldn't sync so I came here and was told to remove all other devices from my account and it worked so now my Aria 2 won't sync back up. What is wrong with Fitbit lately? I even have a regular Aria and that one won't sync either. The only thing that justifies y'all charging SO MUCH MONEY is that is is supposed to sync and track. It's a $10 scale right now.
