01-30-2022
05:28
19:14
DavideFitbit
01-30-2022
05:28
19:14
DavideFitbit
It is taking an extremely long time for the data from my Aria 2 scale to show on my dashboard. The data is getting there and it is eventually showing but not until the end of the day. I weigh myself at the beginning of the day every day. I don't see the data in my dashboard until bed time. This has been happening for almost a week.
Moderator edit: format
02-05-2022
19:14
06:08
02-05-2022
19:14
06:08
Hi, welcome to the Fitbit Community forums, @sigsby.
Thank you for sharing that you're having this inconvenience with your Aria 2 scale.
To set up and connect the Aria scale to your Wi-Fi network, make sure to follow all the steps listed here.
After your Fitbit Aria 2 is set up on your wireless network, it automatically syncs your stats to the Fitbit app after every weigh-in. After you see your measurements, you should see a checkmark, indicating that syncing is complete. You can then view your data on in the Fitbit app. If you experience any inconvenience to sync your data, please make sure to check all the recommendations and requirements in this article.
In addition, keep in mind that it's possible that having other Bluetooth devices nearby could interfere with the syncing process, but many users have found the steps mentioned earlier useful.
Hope this helps, I'll be around.
