01-29-2020
13:06
07:10
JuanJoFitbit
01-29-2020
13:06
07:10
JuanJoFitbit
I just using aria 2 . Can not access Aria 2 forum. Have a problem with Aria 2 . Two problems , first default to guest . Tried to solve problem with Chat . Could not resolve. This morning weight only shows graph . No statistics for today . Not happy with aria 2 scale
01-29-2020 19:56 - edited 01-29-2020 22:46
Hello @Newenergy I've moved your post to the Aria a scale board.
Have you assigned a user to the scale. Then after taking a reading. You so I'll want to use the left/right pads to assign the reading to you??
Best Answer01-29-2020 19:56 - edited 01-29-2020 22:46
Best Answer01-29-2020 20:44 - edited 01-29-2020 20:51
I have assigned the user. Before I lodge request for assistance, I did the obvious checks . This is my second day of using this scale . I tried chat and they were not able to help me . After I did the weigh in, I go to my Fitbit App and I assign the weight to me. I am the only user. I noticed a few aria 2 have a similar problem . Is there a problem with Bluetooth connection?
Sent from my iPhone
Best Answer01-29-2020 22:48
01-29-2020 22:48
Have you assigned the weight to you by using the scale?
As for Bluetooth, the scale syncs directly with Fitbit through the WiFi. Bluetooth is not used at all.
Best Answer01-30-2020 19:58
01-30-2020 19:58
Best Answer01-30-2020 21:22
01-30-2020 21:22
Where you assigning your weight by choosing your icon on the scale, as instructed in your user manual. Or where you assigning the weight through the Fitbit app, as you described.
Best Answer01-30-2020 23:03
01-30-2020 23:03
02-16-2020 16:45
02-16-2020 16:45
I assign it through the aria section via my Fitbit app . When I went through setup there was no option to set me up on the scale . I ask for assistance via chat and it via Fitbit aria section not the scale
Best Answer02-16-2020 16:54
02-16-2020 16:54
I have done that. None of it worked . It just go to guest . Now and again it defaults to me after 4 weigh in .
Best Answer02-16-2020 17:00
02-16-2020 17:00
It never gave me the option to assign me via the scale . I also asked chat to assist me and they could not help . I also deselected the aria and tried again to set up and the option to assign did not occur . I only did it via Fitbit setting s . I
t defaults to me every now and again .
all those options mentioned in Manuel, chat are not working . Aria is not working as per Manuel . I will not be investing in an aria in the future .
Best Answer02-16-2020 17:02
02-16-2020 17:02
The Fitbit scale never gave me an option to default to me . I asked Chat to help and they could not. I set it up via Fitbit settings. The scale does not work as per Manuel.
Best Answer02-17-2020 00:23
02-17-2020 00:23
I have had the same problem. I tested resetting my profile by changing gender (and then back again) and it started working as it should. I am not sure if I did a new setup after changing the profile, there was a lot of meddling and fighting with the scale that day 🙂
Best Answer02-18-2020 03:23
02-18-2020 03:23
I have tried resetting my profile . It did work for a while and then it went back to Guest . Do not be surprise if it happens to you.
i am not happy the aria scale . It should not be this complicated. It is not working as per Manuel. A number of people have had similar problems and there is no real solution . Not sure if I return the scale and get a new one will the problem go away .
