05-29-2022
01:42
18:42
LizzyFitbit
05-29-2022
01:42
18:42
LizzyFitbit
Since owning Aria air scales, when you first step on, the weight given is always a few pounds higher than the following weights. For example, this morning when I first stepped on it said 9st6, then when I stepped on and off it said 9st3 and stayed at that weight, and it’s always done this. Does anyone else’s scales do this, or have any tips? Thanks
Moderator Edit: Clarified subject and updated label
05-31-2022 12:59
05-31-2022 12:59
Hello @Steph09022022
This has happened to me before. I just removed my battery, waited a few mins (1-2), then put the batteries back in. Then I waited a few mins for the scale to calibrate before weighing myself again. This seemed to fix the issue. The big thing is to make sure your scale is on a nice flat surface (not carpet) for accuracy. If you pick up your scale and put it away (some individuals do that to avoid their children playing on them) or store it on its side make sure you wait about 1-2 mins before weighing yourself to allow the scale to recalibrate.
😉 I hope that helps
