02-10-2021
05:26
04:05
JuanJoFitbit
02-10-2021
05:26
04:05
JuanJoFitbit
Hello
I bought my Aria Air at the start of the year. I started using it once a week and it synced to my app fine. Then I started weighing myself daily and found that it only syncs every other day. Other posts say the aria should sync everytime you step on it, which mine does....but only every other day!
Can anyone help explain or fix this?
Thanks!
Moderator edit: format
02-18-2021
04:04
09:37
02-18-2021
04:04
09:37
Hi @JEMcL, welcome to our Fitbit Community. Regarding the syncing issue that your Aria Air has experienced, I'd like you to try the troubleshooting steps that are listed in this help article. After trying these steps, monitor your Aria Aria during the next 24 hours and see if the issue gets fixed.
Keep me posted on the outcome.
