06-27-2015
06:03
07:08
JuanJoFitbit
06-27-2015
06:03
07:08
JuanJoFitbit
I have had my Aria for 18 months or so. Almost a year ago it stopped being able to connect via wifi. I tried a million things and nothing worked. So I gave up. But at least I could weigh myself every day and log the results manually. THe batteries finally got too low and so I changed them .Now I cannot set up anything. It wants to me to go through set up, but of course that puppy stopped working long ago. SO now I have no scale at all. Does anyone have a solution to just get the **ahem** thing working like a scale that has fresh batteries added. I love that FIt BIt had a great IPO recently and all the lovely thank you notes from the leadership. Maybe they can use the investor dollars to actually update unreliable software and hire more people on the customer services desk to help frustrated users.
06-28-2015 22:54
06-28-2015 22:54
I am having the same problem after bizare reading I changed batteries. Now it wont sinc, was happy not now looks like garmin for me.
Best Answer06-30-2015 07:28
06-30-2015 07:28
Thanks for joining the Community @2pupswalker and @Jimmijames. I'm sorry to hear that you guys have been dealing with this issue for a long time now. I was just wondering, have you tried contacting customer support for this? If not, this would be the best recommendation I can provide so you can get back on track. Get in touch with them at http://contact.fitbit.com or by calling (877) 623-4997 between the hours of 4am-8pm PST Mon-Fri and 6am-5pm PST on weekends. Let them know what you have tried, that way they can move on with other recommendations and find a solution to your issue.
Let me know if you have any other questions.
Best Answer06-30-2015 08:47
06-30-2015 08:47
06-30-2015 10:19
06-30-2015 10:19
Best Answer06-30-2015 11:14
06-30-2015 11:14
https://www.fitbit.com/scale/setup/star
Hiya 2pupswalker,
Try this link and let me know if its any good, I think this is the function I used. But perhaps it's just one I looked at. If it's no good let me know and I will continue looking for you. It's out there somewhere.
All Best
Jimmi
07-01-2015 06:36
07-01-2015 06:36
Best Answer07-01-2015 09:30
07-01-2015 09:30
That is great to hear @Jimmijames and thank you for sharing the link. @2pupswalker I believe that calling customer support is the best option, I'm sure they will take good care of you. In case you do not have their number, here it is: (877) 623-4997 between the hours of 4am-8pm PST Mon-Fri and 6am-5pm PST on weekends.
If you have any other questions, please contact me back. ![]()
Best Answer10-31-2015 14:27
10-31-2015 14:27
I have been unable to get my Aria Scale set back up after removing the batteries.
11-02-2015 03:44
11-02-2015 03:44
Thank you for joining the Forums @PatBunFox62! That is strange. Are you still experiencing the same issue? Are you getting an error message when you try the setup process?
03:58
07:07
JuanJoFitbit
11-02-2015
03:58
07:07
JuanJoFitbit
Did you try the link I posted 30 Jullu
July sorry
Jimmi
Moderator edit: merged reply
Best Answer11-02-2015 06:31
11-02-2015 06:31
I am having the same problem with the Aria. I changed the batteries and now it is dead.
Best Answer11-05-2015 10:50
11-05-2015 10:50
what's the reset function on the ARIA?
we're getting the old Hi, sensing, step off, thinking then ERR
does this mean the device is now defective as it seems many other users have the same isue after about 1 yeat?
we love the device but battreries replaced many times and we're not at the max weight
will it need to be replaced?
11-06-2015 15:50
11-06-2015 15:50
Hello there @SBFAU and @2pupswalker! You need to check if there was a change on your network. Try to restart your Aria once again. If that doesn't work don't hesitate to contact Support.
Best Answer03-18-2016 17:15
03-18-2016 17:15
Looking at these posts, it confirms what my frustration senses--the Aria scale is a bad product. After battery change I cannot get any thing from scale (2 years old?). On my account it shows full batteries, but scale itself won't sense anything, appears to be dead. I did reset, several times. Just before I changed batteries I had short episode of not sensing, but reset fixed. I am coming to conclusion that it is unfixable, and I am better off going back to plain old scales and entering weight manually. Does anything in your experience contradict that conclusion?
Best Answer03-18-2016 17:22
03-18-2016 17:22
Best Answer03-18-2016 18:16
03-18-2016 18:16
03-25-2016 13:02
03-25-2016 13:02
Welcome to our Community @seeingsystems and @2pupswalker! If you have tried, I'd like to recommend setting up you Aria scale as a new device again. You only need to follow @SilviaFitbit's post. If that doesn't help, feel free to contact Support, they'll be happy to provide you the assistance you need.
Keep me posted!
08-21-2016 07:53
08-21-2016 07:53
I just tried changing batteries in the aria scale and it is dead. Nothing. I finally see someone is having the same problem. This is ridiculous. I've tried two new sets of batteries. Now I don't have a scale after paying large for one that was suppose to work.
08-21-2016 07:54
08-21-2016 07:54
I just changed the batteries in mine and it's dead. There's nothing there. So much for advanced technology. I'm readet to switch trackers as well, a company making such an expensive, clearly defective product doesn't reallly need my business
