Aria not syncing
ANSWERED
My aria scale will not sync with app. It was syncing everyday with no issues and then I realized it wasn’t changing on the app about a week later. It says it’s connected to the network and displays everything, the line spins like its transmitting but the arrows? Aren’t turning and then at the the bottom of the display the WiFi lines come up with an x over them.  Nothing has changed. It’s been about 20 days since the last sync.
59 REPLIES 59
I just started using my Aria scale again. Hasn't synced since 2/31/17. DounD everything I'm supposed to and still won't sync
@BARBFLEM It's great to see you in our Fitbit Community! Let me go ahead and help you to find a solution for the syncing issue that your Aria is experiencing. I'd just like you to let me know the following details: Are you getting any error message when your Aria tries to sync your data? Have you made changes to your network (router, router settings or WiFi password)? What is the make and model of your router?
This info will help me to assist you accordingly.
Catch you later! Smiley Happy
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
FYI-Same issue here and doing the setup again did not work. I also tried restarting my iPhone, and reinstalling my Fitbit app.  That didn’t work either.
Then i rebooted my WiFi router and now the scale syncs again to my Fitbit app.  I have Frontier as my internet provider.
@Rockgoddessis I'm so glad to hear that your Aria scale is working properly now. Thank you for posting the update here and sharing the steps you followed.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often! Smiley Happy
Same thing . Sept 22nd . Stopped working. Seems like a Fitbit thing .
@ScottyTB Thank you for participating in our Fitbit Community! I'm sorry to hear about the issue that your Aria scale is experiencing. Please let me know if your Aria scale is displaying any error message. Also, let me know if you've made changes to your network such as router, router settings or WiFi password. Finally, I would like to know what is the make and model of your router.
Looking forward to your response! Smiley Happy
I havent changed the network recently.  I'm running just on my XB6 modem and wifi thru out using that.
I may end up calling support when I have time to work on this.
@ScottyTB Thank you for getting back! In case you have not called our Support team, I'd like you to make sure that your XB6 modem runs the protocol 802.11b, bandwidth 2.4GHz and the WiFi password is alphanumerical. These are the router settings required by the Aria. You can verify these settings with your Internet service provider also if you need help.
See you around! Smiley Happy
Hi, I have spent a ton of time with online chat and phone help.  It seems that there is no resolution to the problem??  I am not sure that anything can be done and customer support said your scale is old buy a new one!
Did any of them have you try changing the settings on your wireless router? That's what finally worked for me (see instructions on the first page), although I still need to redo it periodically for some reason.
Thanks and yes I have tried all of the fixes above.  25% of the time I can get it to synch for a couple of hours but then back to no synch.  Seems like the only bandaid is going through the resynch process daily.  Not optimal.  They have not updated the operating system in years (V39) and seem to want users to upgrade rather than support.
Thanks for your comment
Daily!?! Dang, and I thought every couple of months was annoying.
Totally agree, they should have fixed this a long time ago.
I had to get a new router and need to change my WiFi info for my aria scale. I tried to reset, etc and nothing works.
I have a Netgear Nighthawk router. Does anyone have a fix for this?
@Chicago3511 Welcome to our Fitbit Community! I'm sorry for the late response and I'm also sorry to hear about the setup issues you experienced with your Aria scale. I totally understand how frustrating this is for you since your scale is no longer under warranty. I really appreciate your feedback since this helps us to keep improving.
@eagrierson Your contribution and feedback are greatly appreciated.
@Jencpayne Thank you for joining our Fitbit forums! I'm sorry to hear that your Aria scale is not connecting to your network either even though you have changed your WiFi info or settings.
Please let me know the following details: Is your Aria displaying any error message? Is your router running the protocol 802.11b and bandwidth 2.4GHz? If so, let me know also and I'll be glad to follow up.
See you guys around!
Hello.
Im following all’ The instructions ti connect MTY Area, buttiamo not working.
i read all the chats, and looks like somebody needs to help me with my router.
my carrier is AT@T and my router is a Motorola NVG589.
could you guys please support me?
Seems like after 3 years the creators have not been able to find a fix. I would have to resync every day if I had time do that. It’s faster and easier to manually input weight into a fitness app.
Hi, I had the same problem, though connected to the Network Aria would not sync. Firstly ensure that your Encryption Settings Security Mode is WPA2-PSK and only this, with WPA Encryption Mode set to AES in your Modem/Router setup. I did not have to change the password I was using and all connections around the house worked fine with it. I had changed it a while back for another purpose and the Aria worked for a few months with the new setting but stopped syncing a week ago. I did all the resets and then by changing back to the WPA2-PSK Security Mode with AES WPA Encryption Mode it has started syncing to the Network again. My suggestion is, ensure correct Security Mode, then a reset and hopefully that will solve the problem as it did for me. I am running V39 on the Aria by the way. Good luck.
Fix with a hammer when you git pissed off...
Does anyone know how to get my aria syncing if I am on Telus.  I can get to the admin page but no clue where to go from there.  My aria hasn't worked in a year and i gave up.
YES! Sept 22, 2018 was the last time my Aria scale synced with app! Did they add a timer to force us to buy something new?! I've had to manually enter my weight since that date which I could do with ANY simple mechanical scale. Hey, maybe Goggle will do better develop for Fitbit products now that they own them! Fingers crossed.
