01-07-2023 08:41
01-07-2023 08:41
Are you weighing yourself barefoot?
Best Answer01-10-2023 05:34
01-10-2023 05:34
Just used mine for the first time this morning and had the same issue. Only weight shows, no BMI.
01-10-2023 07:17 - edited 01-10-2023 07:20
@TamBan @Debbi32 The Aria Air doesn't show your BMI on the scale. I doesn't "know" who is standing on the scale until you save it on your Fitbit app. You will see your BMI when you go to your weight log on your app and look at the details for that weigh in. I'm the only registered user on my Aria Air. Visiting family can weigh themselves, but only see their weight.
@SunsetRunner I think you are confusing BMI with percent body fat. You don't need to be barefoot on the Aria Air.
Laurie | Maryland
Best Answer01-10-2023 07:21
01-10-2023 07:21
01-10-2023 07:26
01-10-2023 07:26
@Debbi32 Can you verify that you have your height in your personal details? If you have your height there, then I don't understand why you don't see your BMI on your weight log details.
Laurie | Maryland
Best Answer01-10-2023 07:31
01-10-2023 07:31
