09-16-2014
12:27
14:53
09-16-2014
12:27
14:53
The simplest and quickest approach to setting up your Aria scale is by installing and running the setup software from here.
If you are unable to complete the setup with this software, we recommend using the web-based setup as a secondary alternative. Complete instructions for this process can be found in this help article, along with the instructional video below.
Setting up your Aria via the Web-based Method
For assistance with putting your Aria in "Setup Active" mode, please consult this post.
If you are unable to complete the setup process using the above information, check this help article for more setup tips. For further assistance, please contact our Support Team at http://contact.fitbit.com or join the discussion in our Aria Community forum. Be sure to provide as many details as possible about where in the process you are getting stuck and what error you are encountering.
Wow, you were completely unhelpful. You did not answer my question. I had another aria at my house and it worked before. It is connected, I am talking about adding additional users to the device. Please help people in the future.
Best AnswerMy Scales are really just a big lump of useless plastic.
Stopped connecting to Wifi in February.
Tried to reconnect. Have tried 2 routers.
Goes into SetUp mode. Eventually connects to the Aria Wifi, then after proceeding, half the time the web page crashes. The other quarter it gets to the wifi signal screen and half of that time it might see a number of wifi signals (the other, nothing at all).
Tells me its found the Wifi 1 in 4 times, and then "Wifi Err" - reboots straight back to the Set-Up screen.
Useless device - just useless.
Best AnswerI was setting up my fitbit Aria and got to the step where i got the scale connected to the internet and when i went to switch my phone back to my home internet from the scale network, the page went down and when i refreshed it took me back to the home page not where i was in the set up. Now the scale is flashing set up activate but when i attempt to restart the setup i can no longer connect to the scales network. How can i fix this?
Best AnswerOH MY GOD THIS WORKED. My Xfinity router was set to not accept 802.11b devices and I followed Matthews instructions - the only part I had to figure out is that if you have xfinity the login for the 10.0.0.1 page is ADMIN and password is "password" its not your usual login. From there Matthews directions are perfect.
Best AnswerI’m beyond frustrated. I’ve had my Aria for a while now and it used to work like a charm until the Aria 2 came out. Now, I can’t remove my device. I can’t change the Wifi network. I get all the way through the setup process and it it resets back to try again. I’ve purchased every Fitbit device and loved every single one including the Aria but there was no reason to purchase a new scale when I had a brand new one. I hate to post negative things but I’ve spent hours trying to get this scale to set change WiFi networks and I’m over it. What good is a product if you can’t use it? Trash can it goes 😞.
