01-01-2019
08:32
08:45
01-01-2019
08:32
08:45
How to I sync Aria 2 to my iPad automatically? I have to do it manually
@Bentley210509, the Aria 2 does not sync to the device app, it syncs via WiFi to the Fitbit servers. The data from the Fitbit servers is then viewed on your device app. It automatically syncs via the WiFi immediately after completing the weigh-in.
There is no manual sync function for the Aria 2 scale, as @USAF-Larry states, as long as the scale can connect to the WiFi router it should sync.
If it doesn't sync shortly after getting off, there will be an error showing on the scales display.
@Bentley210509 Welcome to our Fitbit Community! I apologize for the late response. However, the information that shared @USAF-Larry and @Rich_Laue is correct. I would like to know if your Aria 2 is syncing and working properly now.
Looking forward to your response! ![]()
