Inconsistent weight measurements
ANSWERED
I am getting very random weights from my Aria 2. If I step on it several times after each other the weghts can differ 2-3 kilos.I have a feeling this is a problem which has started recently, my experience is that it has been accurate before.
It is on a flat surface, not moved, I am barefoot, still and well balanced.
1 BEST ANSWER
Accepted Solutions
Hi, @Ingridjw, may I suggest you install new batteries and reset the scales. Let us know how you get on.
Cheers
Gr4ndp4 | UK
6 REPLIES 6
Cheers
Gr4ndp4 | UK
Thanks! I had done that, but tried again. This time I waited longer before putting the batteries back. It seems to have worked!
Hi, @Ingridjw , I'm pleased you got it sorted out.
Cheers
Gr4ndp4 | UK
The problem came back. Did the procedure again, worked for a while then problem came back again. Any more suggestions? Would a reset with the little button make a difference?
Hi, @Ingridjw you can reset your scales as described on pages 6 & 7 of the manual.
I hope this helps.
Cheers
Gr4ndp4 | UK
I experience the same problem and a battery change doesnt solve the problem. 😞
