11-06-2018
09:01
08:45
11-06-2018
09:01
08:45
I just called Fitbit letting them know that I've had a problem with my Aria scale for some time now noticing that my battery life would last less and less. I've noticed the unit occasionally go on without stepping on it. And now it goes on every 10 minutes!
This is a manufactured defect and they wouldn't replace it after calling them! I should have been calling them during the warranty and not let it get past the one year. Now my opinion about Fitbit has changed. Not happy!
11-07-2018 03:53
11-07-2018 03:53
@gtoth99 It's great to see you in our Fitbit Community! I'm sorry to hear that your Aria batteries drained fast. I'm also sorry to hear that it's no longer under warranty. The warranty period is good for 365 days starting from the date of first setup.
i totally understand how frustrating this is for you and I appreciate your feedback since this helps us to keep improving.
Best Answer01-09-2019 13:34 - edited 01-09-2019 13:35
My scale is having the exact same problem. It turns on by itself and keeps prompting with “step on” uncommanded. I’ve been through 3 sets of batteries in 2 months. It’s getting very expensive.
01-16-2019 03:26
01-16-2019 03:26
@msilagy Thank you for joining us in this thread and our Fitbit Community! I'm sorry to hear that your Aria scale is also turning on by itself. I would like you to try the following: take out the batteries, clean the contacts of your scale with a cotton swab and a little bit of alcohol. This will remove any dust that the the contacts accumulate.
Finally, put the batteries back in and monitor your scale in order to see if the issue doesn't happen again.
Keep me posted on the outcome! ![]()
Best Answer01-16-2019 04:08
01-16-2019 04:08
01-19-2019 07:12
01-19-2019 07:12
@msilagy Thank you for getting back! I'm so glad to hear that your Aria 2 started working properly again. Thank you for posting the update here.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often! ![]()
