10-02-2019
23:02
12:33
LizzyFitbit
10-02-2019
23:02
12:33
LizzyFitbit
Hi,
Got my Aria 2 a couple of days ago. Changed the weight display to stones and pounds with no problem but it refuses to display my weight in stones on the app, only in pounds. I’ve tried cycling between the weight display but no luck. Can anyone tell me if I’m just missing something silly like a little check box somewhere? Or is this a bigger issue?
Moderator edit: updated subject for clarity and label
10-04-2019 12:44
10-04-2019 12:44
Welcome, @PJ1. It's great to have a new face around the Forums!
I'm glad that you got the Aria 2 and thanks for checking the settings for the weight readings. Let's work on this together! While you've adjusted the settings on your scale to record your weight in stones, the Fitbit app also needs to have the same setting so your readings are displayed in stones. To verify those settings, please try the following steps:
Give it a try and let me know how it goes! 😉
10-04-2019 12:44
10-04-2019 12:44
10-04-2019 15:14
10-04-2019 15:14
10-06-2019 11:54
10-06-2019 11:54
Hi @PJ1. Thanks for keeping me updated.
This is fantastic news! You're welcome and I'm glad the steps worked for you. In case you have some spare time, I’d like to invite you to visit our Discussion Board where you will find great tips and encouragement from other members.
Hope to see you around more often! 😊
