Wireless earbuds
ANSWERED
I have Apple Airpods currently.......They randomly cut out at the gym and are pretty much unusable on an outside run. They will not play constant with arm movement, only play if I hold my arm in front of my body.....Not ideal on a distance run. Do not have they same issue on treadmill. Any luck on a fix or product with less issues?
1 BEST ANSWER
Accepted Solutions
Hi @SunsetRunner, I think you may have posted this in the wrong forum.  This is for the Aria 2 weight scale, not earbuds.  Do you have a question about the Aria 2?
one cruise ship at a time!
Pixel Watches 1-4 I Charges 3-6 I Versas 1, 2, and Lite I Inspires 1 & 2 I Ionic I Alta HR I Flex 1 I Aria 2 & Air I Senses 1 & 2
1 REPLY 1
