06-21-2019
03:56
08:45
06-21-2019
03:56
08:45
I have Apple Airpods currently.......They randomly cut out at the gym and are pretty much unusable on an outside run. They will not play constant with arm movement, only play if I hold my arm in front of my body.....Not ideal on a distance run. Do not have they same issue on treadmill. Any luck on a fix or product with less issues?
06-22-2019 06:32
06-22-2019 06:32
Hi @SunsetRunner, I think you may have posted this in the wrong forum. This is for the Aria 2 weight scale, not earbuds. Do you have a question about the Aria 2?
one cruise ship at a time!06-22-2019 06:32
06-22-2019 06:32
