Hi, I've had my Fitbit Blaze about 4 months now and have never had a problem with the better until this week.
I know battery like decreases over time but this was a very drastic change from a good 4-5 days to 1 day!
I fully charged my Fitbit and it lasted about 36 hours, I then turned off notifications, all day sync and silent alarms to see if this would help but it' actually got worse, it now lasts less than 24 hours.
Is this normal? If so I'm really not impressed - it has been dying mid-exercise, resulting in false stats which is really annoying! I don't use the programs on it, just track my day in general and one/two exercises.
10-20-2016
04:10
04:50
10-20-2016
04:10
04:50
Welcome to the Forums @SunsetRunner. If your tracker is not holding a charge, I recommend checking this post where you will be able to find some steps to fix this inconvenience.
I hope this helps, let me know the outcome. ![]()
05:21
04:48
10-21-2016
05:21
04:48
Welcome to the Forums @LXV. Have you tried the steps provided in the previous link? If you haven't, I recommend checking the link and follow the instructions. If you keep seeing problems after those steps, feel free to contact our support team, for a faster response you can contact them via phone or chat.
Let me know how it goes. ![]()
I'm definitely not having this issue. Even though all notifications from texting, email and calendar apps are on in the settings, on the actual watch they are off unless I need them to be on.
It still lasts 5 days, 6 if I wanted to push it.
