03-29-2018
16:45
04:55
AlejandraFitbit
03-29-2018
16:45
04:55
AlejandraFitbit
Battery indicator on my Blaze is blinking red while the App says "Battery Medium". When I recharge the watch, the large icon on the watch shows about 1/3 remaining. The watch and App are sync'd together and all the stats are the same. Stats of App and desktop version are the same.
Did not receive an email/text notification advising low battery.
Why?
Moderator edit: subject
It's great to see you here @fweiss1.
Keep in mind that you need to be constantly syncing your tracker in order to have your stats updated. If the issue is directly with the Blaze battery, you can take a look at this post and follow the instructions provided there, if it is with syncing follow the steps in the Having trouble syncing? post.
Let me know the outcome. ![]()
