02-18-2017 07:07
02-18-2017 07:07
I charged my battery Friday morning. Now the next morning, it is flashing red. Is there an issue with the Blaze battery not holding a charge? Any troubleshooting I can do? Thank you.
02-18-2017 07:32
02-18-2017 07:32
When my blaze gets wonky I'll shut it down from the settings menu. Haven't had your issue specifically, but syncs and notifications will affect battery life. I've turned all day sync off and limit notifications to texts and calls, which has improved battery life.
Best Answer02-18-2017 08:01
02-18-2017 08:01
I tried the shut down feature you mentioned. We'll see if that helps. I did turn off my step reminder. I don't really use that feature much anyway. Thanks.
Best Answer02-18-2017 14:18
02-18-2017 14:18
It's great to have you here @purplemjh79 and @Jcat313! We don't have any bug about Blaze not holding a charge. I would like you to make sure that you're charging it properly. If you are but the battery isn't lasting as expected then please try restart it.
As @Jcat313 mentioned, you may want to check Tips to maximize the battery life of your Blaze.
Hope this helps. Let me know how it goes.
Best Answer02-21-2017 07:44
02-21-2017 07:44
Having the same issue and it just started after I've had the Blaze for a bit. Wondering if you are still having this issue or what you did to fix it.
~Melissa
Best Answer02-21-2017 14:09
02-21-2017 14:09
It's great to have you here @Melissa79! Have you tried the troubleshoot that I mentioned before? If you have but you're still having this kinda of issue, let me know. ![]()
Best Answer02-21-2017 15:28
02-21-2017 15:28
Totally tried all the troubleshooting you mentioned. As a matter of fact, I was in the process of charging my Blaze, again at that point. Got it fully charged and now it's only half charged in a few hours. Help!
Best Answer02-22-2017 04:56
02-22-2017 04:56
Restarting the device seemed to do the trick!
Best Answer02-22-2017 04:57
02-22-2017 04:57
Restarting the device helped a lot. I'd take the suggestions of others who have posted here. Good luck!
Best Answer02-22-2017 04:59
02-22-2017 04:59
Melissa79 maybe try to see if there is a system update. I know calling a tech person can help also. I had a great person help me when I was first using the device.
Best Answer02-22-2017 05:37
02-22-2017 05:37
I am having the same problem.
I've had the Blaze since Christmas.
I always wait til low battery notification then charge fully.
Charge is lasting 36-48 hrs max!
Is this right?
Also, I am not able to use it for text or email notifications either as my phone wont connect to my Bluetooth in the car if it is connected to my Blaze!
All help massively appreciated.
Thanks
Best Answer02-22-2017 09:15
02-22-2017 09:15
02-22-2017 09:22
02-22-2017 09:22
Turns out there is a problem with mine so I'm getting a replacement after talking to customer service. Your description sounds very similar to my experience...I would call customer service if I were you.
Best Answer02-22-2017 09:47
02-22-2017 09:47
05-16-2017 06:06
05-16-2017 06:06
Same problem with mine ..
Not holding a charge ..
Best Answer05-16-2017 13:07
05-16-2017 13:07
It's great to have you here @Liz321! I would like you to try the following troubleshooting: restart your tracker, make sure you're fully charging it. Also, you can check the tips to maximize the battery.
Best Answer05-31-2017 04:33
05-31-2017 04:33
I had a problem with mine not holding a charge as well. I have had mine for almost a year now. At first it held a charge for about 4-5 days with the HR monitor off. Then it got down to about 2-3 days which was ok with me. Now, almost suddenly it goes from full charge to flashing red in literally 3-4 hours. I called the customer support line, they verified the battery issues on their end using my account and are sending me a new one in the mail. If you are still within the warranty then give them a call. The warranty I believe is 1 year.
06-20-2017 04:26
06-20-2017 04:26
I am having a similar issue with my Blaze I bought in January. It charges fully, then within 6 hours is completely drained. Is there any help I can get to how to fix this? Or do I need to request a replacement?
Best Answer06-20-2017 04:36
06-20-2017 04:36
I contacted customer support. They were able to verify the pkwer issues tbrough my account and sent me a new one. They were super helpful and put a rush delivery on it for me.
