02-19-2017 04:48
02-19-2017 04:48
Is anyone else having issues with the battery of the blaze not staying charged longer than a day after fully charging it?
02-19-2017 05:14
02-19-2017 05:14
I charged my blaze fully Thursday morning and the next morning I woke up and it is blinking red. Same thing happened again yesterday. I charged it fully and I woke up this morniing and it is almost dead again. I don't have notifications turned on at all.
02-19-2017 06:23
02-19-2017 06:23
I have had my blaze for about a month and last week it quit holding a charge. I tried turning off all notifications to see if that was causing it and it was red by the end of the day with a full charge in the morning.
02-20-2017 06:14
02-20-2017 06:14
This is my issue as well! I turned off my notifications, the thing where you raise your arm and it turns the screen on... and I have only synced it to my phone once a day and about half way through the day it's blinking red and by time 6-7 pm it's shut off from being dead!
Best Answer02-20-2017 06:16
02-20-2017 06:16
I'm wondering if there is a new update for it that fixes it like it did the last time but I haven't seen anything for it. I've had mine since Father's Day last year and it's been great until that first time I had to update it a few months ago. Now it's just doing the same thing again!
Best Answer02-20-2017 06:33
02-20-2017 06:33
A warm welcome to the Community @Annie74, @Broadway and @CoachRobbie! I appreciate the details that each of you have mentioned. I would like you to make sure that you've charged it properly. Also, you can try restarting it and see if it improves its battery life.
Additionally, you can check this tips in how to maximize your tracker's battery life.
Hope this helps. Let me know how it goes.
