08-24-2018 09:59
08-24-2018 09:59
SInce the 2.77 update my Blaze will not hold a charge more than a day. I have power cycled it and fully charged it and that did not help...Any Thoughts?
08-24-2018 10:03
08-24-2018 10:03
I am having the exact same problem and have tried restarting it and giving it a full overnight charge. This morning it went from showing a full 100% charge to completely dead before 10:00AM.
08-26-2018 05:52
08-26-2018 05:52
I have exactly the same problem. I think it is possibly down to the firmware update not installing properly.
Does anybody know if the Blaze can be restored to factory defaults? If it can then the latest firmware could be re-installed, hopefully properly.
08-26-2018 06:19
08-26-2018 06:19
I've got the exact same problem. It's driving me mad as I keep thinking I forgot to turn the plug on to charge! Any recommendations to solve the problem?
08-26-2018 21:39
08-26-2018 21:39
My wife and I have noticed the same issue on our Blaze trackers. Our battery life has been cut to less than half of what we were getting before the update.
i don’t know what Fitbit did but I hope they fix it soon.
08-28-2018 13:04
08-28-2018 13:04
Same here - just went through the process to have it replaced because it's down to 25% after 5 hours. However it sounds like I might get a refurbished one? Wish I just waited a few more months and knew about the Charge 3.
Best Answer08-28-2018 13:13
08-28-2018 13:13
Contacted support and they will not acknowledge their firmware broke both my trackers.
Best Answer08-28-2018 14:14
08-28-2018 14:14
Best Answer08-30-2018 11:07
08-30-2018 11:07
I have sent 9 messages to Fitbit starting 8/12/18 regarding the battery drain issue. My $300.00 Blaze is 18 months old so it is beyond the 12 Month Limited Warrenty. They have not offered to repair or replace the tracker but offered a 25% discount towards a new one. This is unsatisfactory.
Best Answer08-30-2018 11:10
08-30-2018 11:10
I was considering an upgrade to the Versa before this happened but now I’m researching other brands.
08-30-2018 16:37
08-30-2018 16:37
And the 25% discount is only on select products not all of them!
Best Answer09-01-2018 06:39
09-01-2018 06:39
09-01-2018 06:49
09-01-2018 06:49
I too have deleted and reinstalled the app and am getting a little more life out of my battery. Still not even close to what it was before the update.
I am very disappointed in how Fibit is handling this situation, I have always been a faithful customer for as long as I can remember and 25% off a new device doesn't feel like GOOD customer service to me....:(
09-05-2018 06:03
09-05-2018 06:03
Hi guys, I hope you are doing fine.
I appreciate all the efforts in trying to fix this. If you have already tried the steps in this post and your battery still not lasting, feel free to get in touch with our support team.
For a faster response you can contact them via chat and in the meantime, check our warranty policy.
See you around. ![]()
09-05-2018 06:27 - edited 09-05-2018 06:32
I don't understand how it was fine before update and now I am having battery issues, for a $300 investment, I would hope for more than a "sorry about your luck...".
09-05-2018 08:55
09-05-2018 08:55
Fitbit to users:
Don’t worry if our update bricks your device, our warranty will cover you unless, of course you’ve had it for more than a year, then, screw you.
Best Answer09-05-2018 16:37
09-05-2018 16:37
I agree- the response I received was that this was a software issue and that my device was not defective. So therefore Fitbit will not replace it but will work on a resolution. Meanwhile my 1 year warranty will be up in November of this year. How is this acceptable? It is a known software issue that has nothing to do with anything that was done by the user- shouldn't that be covered by warranty for a replacement. I don't get it. Definitely Not happy with this type of customer support-
Best Answer09-05-2018 17:57
09-05-2018 17:57
Same here. Sure seems like they're just trying to force those with older devices to upgrade and spend more money. I think I'll look into Samsung...
09-08-2018 11:08
09-08-2018 11:08
Upgraded to 2.78 and my Fitbit is now usable again, however still not up to pre 2.77 battery life.
Battery life:
pre-2.77 with hrm on - ~40hrs
2.77 with hrm off - >12hrs
2.78 with hrm off - ~20hrs
so 2.78 is an improvement but there’s still something seriously wrong.
Best Answer09-10-2018 03:53
09-10-2018 03:53
