06-02-2017 06:36
06-02-2017 06:36
Hello All,
My Blaze battery was lasting almost a week and then suddenly it started lasting less than a day. I read the other messages on the forum and most of them suggested it could be a defective battery. For me, I had turned off the bluetooth on my phone. When I turned the bluetooth back on and the watch was paired with my phone the battery life has gone back to normal. If you are having a battery issue, make sure you check and make sure your bluetooth is on. I guess when it is searching for a Bluetooth connection it is using extra battery power. Hope that helps somebody!
E
06-02-2017 09:33
06-02-2017 09:33
@EricH1 Great suggestion! I wouldn't have thought about that.
Best Answer06-02-2017 13:51
06-02-2017 13:51
I wish that resolved my battery draining problem! Tried all recommendations in the community plus help from Fitbit support & still draining in about 8 hrs after fully charged.
Best Answer06-11-2017 06:10
06-11-2017 06:10
A warm welcome to the Community @EricH1, @Jrdubyakc thanks for stopping by and @KerrySue8 it's great to see you around.
@EricH1 Thanks for the tip provided to make the Blaze battery last more time, I know some users will find this helpful. @KerrySue8 if you haven't tried this, I recommend taking a look at this post and follow the instructions provided there.
Catch you later. ![]()
