05-16-2016 12:35
05-16-2016 12:35
Hi All,
I got a fitbit blaze since a couple of weeks and now the heart rate monitor refuses to work.
At first it did not work too, but when doing my first run excercise it started working and showing my heart rate.
It worked since than without a problem.
Now during my last run exercise on 14th May it stopped working and since than I was unable to get it working again.
I tried a hard reset several times, I tried shutdown several times, I changed heart rate setting to Off, On, Auto, but still no luck.
I am out of options.
Is it possible to factory reset a Blaze?
Thanks for any feedback or help on this topic.
Koen
Best Answer05-16-2016 13:10
05-16-2016 13:10
As far as I am aware a Factory Reset and a Hard Reset is the same thing.
How tight do you wear your fitbit? If it is too tight that may affect the ability to accurately read the heart rate.
Is it all sweaty? Have you tried wiping down the outside of the fitbit where the sensors are?
If it consistently has problems I'd try contacting support, but there are some trouble shooting steps that can be taken first to see if it isn't an issue with the blaze itself.
Best Answer05-17-2016 11:20
05-17-2016 11:20
The lights stopped flashing.
Which troubleshooting steps can I undertake?
Best Answer05-17-2016 12:45
05-17-2016 12:45
The easiest thing to do is reset the device. Hard reset by holding down the bottom right button and the left button for 15 seconds until it vibrates, or go to settings on the fitbit tracker itself by scrolling all the way to the right and at the bottom selecting shut down. Today my tracker started acting up and wasn't picking up my heart beat for a bit so i reset it and it worked fine since. Sometimes it just needs to be reset.
05-17-2016 13:15
05-17-2016 13:15
Thanks @fudge22! 🙂
@kvo181 Sounds like you did quite a bit of troubleshooting, it might be time to reach out to Customer Support so they can take a look.
05-18-2016 13:15
05-18-2016 13:15
Hi All,
it seems to be a software problem.
Got in touch with customer support and they helped me troubleshoot.
They also told me they are working on a fix.
So anybody having the same issue, we just need to wait for the fix 🙂
Br,
Koen
Best Answer08-04-2016 06:46
08-04-2016 06:46
kvo, did you get yours fixed? I am having the exact same problems. Just started this week.
08-08-2016 23:43
08-08-2016 23:43
Best Answer08-08-2016 23:52
08-08-2016 23:52
Best Answer08-19-2016 05:27
08-19-2016 05:27
Hello @MeganCRNA welcome to the Fitbit Community! I would like to ask if the back lights of the tracker are on? If they are not flashing make sure the heart rate setting is "On" or "Auto", and try to restart the Blaze as advised by @SunsetRunner on this post. If they are flashing and the heart rate is not showing on your device, experiment with wearing the tracker higher on your wrist during exercise. Because blood flow in your arm increases the farther up you go, moving the tracker up a couple inches can improve the heart rate signal. Do not wear your tracker too tight; a tight band restricts blood flow, potentially affecting the heart rate signal. That being said, the tracker should also be slightly tighter (snug but not constricting) during exercise than during all-day wear. And contact back our support team if after this your Blaze is not recording your heart rate @kvo181 thanks for sharing your experience. @csbhockey are you still experiencing issues with your heart rate? Have you tried any troubleshoot?
Let me know if you have any questions! 😉
It is health that is real wealth and not pieces of silver and gold! Share your story!
08-19-2016 05:36
08-19-2016 05:36
09-28-2016 18:57
09-28-2016 18:57
11-24-2016 10:07
11-24-2016 10:07
Hi, I noticed my Heart Rate monitor stopped worked as well for my Blaze. I went into the settings option and saw that the Heart Rate monitor was off.
Not exactly sure how it went off, been using it for months. Anyway, if the green lights are not blinking on the back, go into the settings options on the watch itself and change to make sure Heart Rate is On.
Kind Regards,
Mark
Best Answer12-05-2016 16:45
12-05-2016 16:45
Thanks. Mine too isn't working
Best Answer12-07-2016 14:51
12-07-2016 14:51
Hello
if you haven't been syncing with your phone it shuts off I've had that problem too with another Fitbit that or charging it and then trying it
hope this helps
12:09
07:27
12-18-2016
12:09
07:27
Hi there everyone! Great to see you in the Community! 🙂
Please take a look at this post with some things to try and keep in mind to have a good heart rate reading and if after trying those suggestions you're still having problems, I would recommend getting in touch with the Support Team for them to take a deeper look and help you out.
Anything else, let me know. I'll be happy to help!
08-12-2017 10:24
08-12-2017 10:24
Mine did the same thing and I took the advice that was here and reset my Blaze......heart monitor now works perfectly! Thanks everyone!
07:08
07:27
08-14-2017
07:08
07:27
That's great to hear @kflybye!
It's great to see you in the Community Forums and to know that you're back on track. Let us know if you need anything else!
You might also want to take a look at the lifestyle discussion forums for interesting topics you might find helpful!
10-19-2017 14:13
10-19-2017 14:13
My Blaze had this problem that started either yesterday or this morning. It was showing "--" for heartrate and the green lights were not flashing. I fixed by doing a reset following instructions at: http://help.fitbit.com/articles/en_US/Help_article/1186
Bob
10-23-2017 11:28
10-23-2017 11:28
Hey there @Duncanson, thanks a lot for jumping in and sharing this with us! I'm pretty sure many users will find it helpful! 🙂
