Blaze Screen flashing
ANSWERED
So I woke up and noticed my blaze screen is constantly flashing as if its showing the old school TV static screen. Any idea on how to fix this issue? This is the first time I've experienced this.
250 REPLIES 250
Hi I have read through the suggested solution of rebooting the device but the screen is flashing and the screen is dull I can hardly see the display. Any advice what to do with it? It is my second fitbit merchandise I bought 😞
Previously my charge HR could not charge, now its the screen for blaze. Here is an image of the display of my blaze now. I can hardly see the display
flashing display screen on blazeflashing display screen on blaze
Thanks, the reboot solved the issue 👍
Good morning,
My Blaze Fitbit needed to be recharged and when I put it in its charger, the Fitbit logo is flashing on and off.  I have tried a restart, holding it for 10 or more seconds and nothing changes.  Can someone help?  Thanks!
Mine was doing the same thing! Restarting has helped thanks
Hello.
I picked up my fitbit blaze and it was suddenly flashing like an old tv.
I tried to reset the fitbit blaze by pressing the left and lower left buttons.. it restarted but the screen is still flashing
Please help me out
I too have started having issues with my Fitbit Blaze screen today .It keeps flickering, and then stops responding and shuts itself down, & won't restart for several minutes. It also seems to lose charge soon after recharging. I have reset it as suggested, but this does not solve the issue. Please help!
Mine was not able to be fixed & the warranty was up, but they did give me a
discount for a new one.
Thanks Ferdinand , your suggestion worked for me also! yay!
Same problem for me.  Help!
Hi Ive owned my fit bit for less than a year.. today in the middle of my run.. the screen started flashing with lines across the screen.. not really able to see the numbers.. I ran 11 miles but it only tracked 5.5... I tried holding down the lower left button for 10-12 secs... NOTHING. I now longer have the box.. I only know I where I purchased it.. training for NYC marathon.. I really need to get this fixed. Please help.
Kemp18 my fitbit blaze did just that the flashing I thought its going to give out so I did just what you said on restarting the tracker and it worked so thank you thank you so much***** 🙂
Mary N
Thank you, I was having the same problem and this corrected it.
Linda
Oh hooray! I did not know how to reboot my Blaze. I did and so far, so good. Thanks!
Good afternoon,
My watch is flashing like an old school television that is about to fail/die. I've tried the shutdown button under settings and also have tried holding down the left and lower right hand buttons simultaneously. Was unable to do a reboot. Perhaps I'm doing incorrectly. Not sure what to do next. Please help
Sorry but I do not know what else to do. The only thing I did was hold
down both buttons at the same time and that corrected by problem,
Thanks for the reply. That's what I did and it seems to have resolved the
problem.
Awesome! I had the same issue and the reboot worked.
Thank you! I was having the same problem and it worked perfectly for me!
Hello
I also had the same problem and the screen also has lines through it and fades in and out and goes to a black screen.
Please help!
Thanks 😃
I'm so glad it helped. :)Mary
Sent from Yahoo Mail on Android
