03-09-2017 04:59
03-09-2017 04:59
Same issue over and over again. Anytime there is an update, I lose my text and call notifications. I am getting no text messages now, no call notifications, no calendar notifications. For some reason, Samsung is pushing notifications to my phone for fitness stuff that I haven't asked for? I spend a ridiculous amount of time getting things back into sync. This is never a quick and easy thing. With that said, why does this continue to happen? For several months, things have been fine and then update and all is shot... Also, please post simple step by step instructions with screenshots to correct this. Constantly doing this makes me question the price point on the Blaze. Too much work to keep it synced...
Best Answer03-09-2017 07:06
03-09-2017 07:06
It's heard to say why you are experiencing this, most do not. Samsung adds it's own skins to their Android phones and sometimes they may also interfere. Next time this happens, try going to settings/apps/Fitbit on your phone and then choose force stop and then clear cache or storage and then clear cache. Launch the Fitbit app after that and see if that resolves your issue.
03:19
08:41
03-10-2017
03:19
08:41
It's great to see you around @ScrapBandit and @SunsetRunner thanks for stopping by.
If you are having problems with your notifications, I recommend following @MarreFitbit's instructions in the My tracker isn't receiving notifications (Android Fitbit app) post.
I hope this helps, let me know how it goes. ![]()
