01-10-2018
00:05
07:03
FerdinandFitbit
01-10-2018
00:05
07:03
FerdinandFitbit
Hi everybody! I don't usually uses blaze while I work. I put it on the table. After about four hours, the blaze turned to 60% batteries from 100%. Any power-down mode can I use in the blaze?
05-21-2018 12:33
05-21-2018 12:33
Another Blaze here with an apparently end-of-life battery.
Like you others I have gone from charging every 5 days to every 5 hours.
I have loved the last couple of years of being able to walk past watch shops as I would never take off my Blaze in case I lost some steps.
I was thinking about moving up to a Versa but not if it suffers from the same battery issues (though 75% off rather than 25% may change my mind).
I am looking forward to hearing about the battery replacement attempts!
Cheers
05-21-2018 14:56
05-21-2018 14:56
05-23-2018 00:37
05-23-2018 00:37
When is Fitbit going to take the Blaze off the market. It's battery is faulty and they know it. So many consumers complain about it. You should not replace the battery.
What is the expected life time of a Fitbit Blaze. My first one lasted 14 month, my replacement 8 months. Fitbit won't replace it for me again.
This is a very expensive gadget and a very risky buy. I am certainly never going to buy a Fitbit product again.
How can consumers protect themselves from this kind of business?
05-23-2018 00:49 - edited 05-23-2018 00:50
Well, replace it yourself ... 10 minutes of your time and $5 for the battery 😃 and you are again good to go ...
my battery lasted 25 month (original) and the replacement expanded the battery life to 6/7 days / charge 😃
05-23-2018 00:52
05-23-2018 00:52
Where did you buy your battery for Blaze. Thanks man
05-23-2018 00:58
05-23-2018 00:58
@Deividas wrote:Where did you buy your battery for Blaze. Thanks man
05-23-2018 03:29 - edited 05-23-2018 03:39
Same!! My Aria lasted 13 months. My Blaze has NEVER held a charge the way it should... But after only a few months, I'm literally down to one day. I called when it went down to 2.5 days or so, and they were ridiculous. Wanted me to jump through all these hoops to "test" it, when we all know they can see the cycle of charge and drain. I don't have time for that nonsense, but I guess I'm going to have to do it now to get a replacement. Blaze is a very expensive **ahem**, [haha -- they bleeped a common acronym for "piece of....."], service is deplorable. Heading over to Garmin next time.
05-23-2018 03:32
05-23-2018 03:32
On a Blaze?! I would totally do this!! Can I find instructions online or something? Have no idea how to get into it, nor what type of battery to buy. Thanks!
05-23-2018 03:35
05-23-2018 03:35
I'm sorry -- saw the battery info in the thread. Have no idea how to get to the battery, but can likely figure it out. Thanks!
05-23-2018 05:15
05-23-2018 05:15
The battery is not supposed to be replaced. Fitbit customer service made it clear to me. The Blaze is just a big mistake and I really think that they should reimburse all of us even if it is no longer under warranty, just like it is done with other products.
I switched over to Polar.
Is customer service even reading our complaints?
05-23-2018 09:46
05-23-2018 09:46
@Carola_Kirchner wrote:The battery is not supposed to be replaced. Fitbit customer service made it clear to me. The Blaze is just a big mistake and I really think that they should reimburse all of us even if it is no longer under warranty, just like it is done with other products.
Nah that is just a lazy answer....
it is supposed to be replaced otherwise the case would not just pop open after you unscrew the 4 little ones -> the whole replacement takes 10 minutes...
Even if "they" do not do it ... look for somebody who can solder and can open the 4 screws and you are done and good to go again.
Easy. If you live in Europe i can send you a battery 😉
05-23-2018 10:45
05-23-2018 10:45
05-24-2018 01:37
05-24-2018 01:37
I live in Namibia. My point was that one should be able to charge the battery and by replacing the battery would it still be able to be charged.
I will take it to a local watch dealer and see if they can help me.
05-24-2018 02:43
05-24-2018 02:43
Did not get that 100% but do you want to know if you can charge the watch after replacing the battery?
The answer is yes .... fitbit does not even know that you changed it ...and it works ... you just need to get the right size for the battery 😉
05-27-2018 14:06
05-27-2018 14:06
I've done all this..and this doesn't make any difference what so ever ...I've been contact with support who informed me that there is an issue and tech team are dealing with this problem ...
05-29-2018 07:46
05-29-2018 07:46
hi, my fitbit has suddenly started needing a daily charge as well, odd that there are no posts regarding the success or failure of replacing the battery. if anyone has managed it successfully please post as i am reluctant to go back to a Garmin or something similar.
thanks in advance.
05-29-2018 08:46
05-29-2018 08:46
05-29-2018 10:05
05-29-2018 10:05
thank you for replying, i guess it takes a long time to get a battery then...i didnt realise China was the only option for replacement ((just assumed the cheapest) i will watch a tutorial tonight after work and then decide if thats the right way for me to go. i dont have the most delicate touch but am prepared to have a go at most things ask my gf 😉
failing that im not sure, had a garmin perviously it was okay. much better battery life but it was cheap and limited, this was my first foray into a smart watch/tracker. generally very pleased but the battery thing seems to be a big ball ache and if im paying £150 plus i dont expect these issues.
again thanks for your info 🙂
05-29-2018 10:12
05-29-2018 10:12
05-29-2018 13:40
05-29-2018 13:40
Interesting! My Blaze's battery has suddenly started behaving itself. I checked my phone the other day and discovered that it hadn't synced with my Blaze since early May! Once I fixed that issue, battery life appears to be OK again but I am monitoring it closely. Definitely not burning juice as quickly as it was. Anyone want to but a spare 302030 Lipo battery?
