Blaze battery draining
Hi,
My Fitbit Blaze is draining battery rapidly after the update to this version - 17.8.402.1.
The battery gets drained within 12 hours, even though I am not using it for any exercising video or workouts sessions or has not even set up any alarm reminders. I would request you to to please clarify and solve this issue at the earliest.
1 REPLY 1
It's great to welcome you @Apoorv_Chauhan.
If your Blaze battery isn't lasting the time it should, I recommend taking a look at this post and follow the instructions provided there.
I hope this helps, let me know the outcome. Smiley Happy
