10-08-2016 20:01
10-08-2016 20:01
Best Answer10-08-2016 20:03
10-08-2016 20:03
Hmm thats weird. So does my charge HR. I suggest you should contact support
@Bunyen wrote:
My blaze shows full charge on the dashboard but one bar on the tracker. It won't charge when in the cradle. It dies when trying to use. In the cradle it's on but the battery bar flashes on the top right. It's been charging for over 24 hours which is more than enough time. I've also cleaned the contacts as directed. Any help would be appreciated.
Best Answer10-09-2016 08:49
10-09-2016 08:49
A note about the dashbiard, it only knows the battery status during the last time your tracker communicated with the Fitbit server, are what would be called a sync.. You dashboard will tell you how long ago that was
10-09-2016 20:11
10-09-2016 20:11
Thats right. Sync your blaze for up to date details.
You can do that by opening the fitbit dashboard and click the 2 arrows that is shaped like a circle
Best Answer01-05-2017 07:02
01-05-2017 07:02
I am having this issue also but I just synced and there is a difference.
