I bought my fitbit blaze 2 weeks ago but I have noticed some fluid on my charger and my fitbit and I assume it's coming from the battery because it's on the back part of the fit bit I can't return it to the store will fit bit replace it or refund it or how does that work
Best Answer@Davidkeith the warranty link may be found at the bottom of every page.
Are you sure it is not persperation? The Blaze is pretty well sealed, and the battary is solid, no liquid in it.
Best AnswerYea I've noticed this problem aswell. So the battery is solid? Is there any other peice that could have caused it? I saw liquid on the charger and I used a wet tissue to try and rub it off but it didn't seem to work so it has to be some type of chemical, right😅?
Best AnswerMine started leaking a brass solution after about two years. It was visible coming out of all seams, and screwed connections.
