02-25-2016 09:19
02-25-2016 09:19
Just got my Blaze. Couldn't figure out how to get it connected to the charger because of the lack of documentation. I'm not sure I'm digging the requirement to remove the face from the band every time I need to charge it.
I did manage to add it to the fitbit app on my phone and immediately I'm waiting over 30 minutes for a "10 minute" firmware update. It's 25% done now, so I have that going for me.
Anyone else verify that their update took so long? Just wanting to ensure whether or not the problem might be with my phone.
Thanks!
05-23-2016 18:01
05-23-2016 18:01
Best Answer05-24-2016 21:25
05-24-2016 21:25
LcMarie,
Exactly the same issue. Starting googling and found this site. Im completely astonished at how difficult the process has been and how much time Ive spent so far in simply trying to turn this on!!
Im on update attempt number 4, 2 failed outright after about 45 minutes, no reason given, next one failed due to battery dying, then no clue if recharging or not, just that horrible fitbit.com/setup on the screen, nothing else.
Sat it into its cradle and no clue if recharging as no indicator of any kind. Some lady from fitbit on here keeps referring to a manual that wasnt sent with the device? Gee, thanks, and she says reset the Blaze?? how do we do that? How do we know we need to do that?
Number 4 is on about 50% after 1 hour.... but I suspect the battery may lose me again...well maybe, but who knows.... my roomate is laughing aty me because I'm not getting Fitbit step credits to all the up and down and stomping across the room Ive been doing to the device and my phone...
Really is a joke that some thing so expensive and after 2 days, I cant actually turn it on or use....if this doesnt work, I will return for a refund and switch to a different brand.
05-24-2016 23:22
05-24-2016 23:22
Best Answer05-24-2016 23:26 - edited 05-24-2016 23:27
@LcMarie and @dunkie26 that is true, there is no way to tell if the tracker is charging or what amount of Charge it has. Many have just left the Blaze in the charger during the update procedure.
One more point, when restarting the update, the tracker will continue from where it failed, it won't be starting from scratch. As long as the progress bar increases I just continue to try.
As for the manual, all Fitbit devices will only work if can be connected to the internet. Therefore Fitbit has placed all the manuals online, this also allows them to actually be readable.
To find the manual scroll down to the bottom of the page, click on the Help link, or through the phone app -menu-help-help articles.
Now click on the picture of the tracker, on the next page you'll see the interactive help menu, along with the Blaze 101 and the users manual.
05-25-2016 05:00
05-25-2016 05:00
05-25-2016 05:53
05-25-2016 05:53
Update:
Finally charged on number 4. Multiple issues as mentioned, and a very poor experience overall for me. Its my first fibit watch.
Best Answer06-15-2016 19:25
06-15-2016 19:25
This is taking me about one hour and half on my Samsung S7 Edge. Can't believe Fitbit has not fixed it.
Best Answer06-16-2016 04:40
06-16-2016 04:40
Best Answer06-16-2016 11:22
06-16-2016 11:22
My firmware update took about 6 or 7 minutes. This was AFTER I had to return my other one because the battery was empty and it would never charge. Stayed at the setup scvreen. Told me to do update and then said battery was too low. Luckily, Wal-mart took it back since it was only 90 minutes from the time of purchase. After that, it was smooth sailing. Love the Blaze!
07-06-2016 18:25
07-06-2016 18:25
Best Answer07-06-2016 19:46
07-06-2016 19:46
@Butrfly13181 wrote:
Of ANY instructions. Like which button is which... Anything! Bueller.... Bueller....
If I understand your question, all can be found in the beginning of the manual:
https://staticcs.fitbit.com/content/assets/help/manuals/manual_blaze_en_US.pdf
07-06-2016 20:32
07-06-2016 20:32
From the Fitbit intractive help site, click on the word Help thats found at the bottom of the page
Best Answer07-28-2016 10:55
07-28-2016 10:55
I am approaching 40 mins on my update using a Motorola Droid Turbo 2. This is AWFUL
Best Answer07-28-2016 13:38
07-28-2016 13:38
@Jeanbop do you see the progress bar increasing?
Some have reported problems connected to WiFi and found the cell network worked fine.
In any case if it has gone 10 minutes than cancel and start again.. It should only take 8-10 minutes tops.
Best Answer07-28-2016 16:45
07-28-2016 16:45
Best Answer08-26-2016 18:03
08-26-2016 18:03
Fitbit is worse than apple when it comes to placating customers with lies.
I have an extremely fast internet connection. After 40 minutes, I'm not even 40% of the way through updating.
Best Answer08-26-2016 20:10
08-26-2016 20:10
Best Answer08-27-2016 08:42
08-27-2016 08:42
@Chopfyt if it was me i would kill the app, then restart the update, maybe even restart the tracker.
After doing 8-10 updates on various trackers, I haven't seen an update take more than 8-10 minutes. Even with only a few bars.
I'm not sure which phone you have, but for some android phones running marshmellow it was determined that the update doesn't work over WiFi and needs to be done through cellular network.
Best Answer08-27-2016 08:52
08-27-2016 08:52
Best Answer08-29-2016 05:00
08-29-2016 05:00
Hello everyone! Thanks for taking the time to visit this thread and share your experience with the set up process. If you are experiencing issues with the initial firmware please troubleshoot as instructed by @SilviaFitbit on this post. Also if you are using a mobile device please review the compatibility on this list. If you already did this and you are still unable to continue with the set up process please reach out to our support team for assistance.
I'll be around if you have any questions! 🙂
It is health that is real wealth and not pieces of silver and gold! Share your story!
