02-25-2016 09:19
02-25-2016 09:19
Just got my Blaze. Couldn't figure out how to get it connected to the charger because of the lack of documentation. I'm not sure I'm digging the requirement to remove the face from the band every time I need to charge it.
I did manage to add it to the fitbit app on my phone and immediately I'm waiting over 30 minutes for a "10 minute" firmware update. It's 25% done now, so I have that going for me.
Anyone else verify that their update took so long? Just wanting to ensure whether or not the problem might be with my phone.
Thanks!
08-31-2016 19:21
08-31-2016 19:21
I waited for about an hour while i did things around my dorm and then bluetooth failed me. I'm trying for the second time. Hoping to go on a night run before it rains 😞
09-02-2016 08:00 - edited 09-02-2016 12:29
Hello @SunsetRunner! Where you able to set up the Blaze? If you have any issue please troubleshoot as instructed by @SilviaFitbit on this post.
Catch you later! 🙂
It is health that is real wealth and not pieces of silver and gold! Share your story!
09-26-2016 21:07
09-26-2016 21:07
Update through the phone. You'll be much happier.
09-27-2016 20:20
09-27-2016 20:20
09-27-2016
22:34
14:15
SilviaFitbit
09-27-2016
22:34
14:15
SilviaFitbit
The best thing I found was to make sure your old Fitbit is un linked, once we did that and started over it was all smooth sailing!
Jessica Johnson
Moderator edit: Removed personal information
09-28-2016 02:01
09-28-2016 02:01
@Jdgarcia2011 I to noticed the descripancy between the app and the Blaze completion bar. My update was taking forever, so I killed the app and started it all over, completed in 5 minutes.. To kill the app and start again is the usual fix for a slow update.
I did not remove any of my trackers, (Force, Blaze, Charge 2, Charge HR, and Zip) for the many firmware updates I have done
09-29-2016 14:07
09-29-2016 14:07
10-07-2016 10:59
10-07-2016 10:59
i have been trying to update my fitbit blaze for an hour and it says it is unable to complete it at this time. I have my bluetooth on, both devices are inches away from each other, and everything is fully charged. Any suggestions? This is becoming very frustrating
10-08-2016 04:22
10-08-2016 04:22
10-09-2016 23:11
10-09-2016 23:11
I have been trying to update firmware for the last 2 weeks. The blaze has been intermittently syncing after I reset and uninstall and reinstall the app.
Neither my phone (HTC M10 Android) nor my PC could locate the tracker. Finally I did the old tracker reset, then uninstall and reinstall app, try again - my phone found the tracker and started to update.
After 50 minutes of updating, the progress bar was about a quarter through so I restarted phone and tracker and tried again. The second time it took about the recommended 10 minutes.
Fitbit you know all of the people that have the Blaze and have not updated, why not get on the front foot about this issue? Reading these posts confirms that it is a widespread issue.
Personally I am cranky that I wasted so much time over the last 2 weeks thinking it was me and my setup - when it is not, it is a Fitbit problem.
10-09-2016 23:59 - edited 10-10-2016 00:02
As for things to try restart Blaze, restart phone or pc, try a different device, or try the pc through the charging csble, no BT needed.
I'm sure Fitbit can tell who has and who hasn't updated, knowing within a ballpark figure of how many where sold.. Looking at the few here, and 6 people know with the blaze I'm not convinced it is universal widespread problem.. Only one of the 7 took longer than 10 minutes.
10-10-2016 14:36
10-10-2016 14:36
Fair enough, but we'll have to agree to disagree. As the owner of a SaaS company I may have a different perception of what leading practice is, especially for a company with a market cap of nearly $3b
11-19-2016 19:10
11-19-2016 19:10
trying to set up mu Blaze fitbit and its been doing the update for 2 hours. any suggestions?
11-21-2016 10:41
11-21-2016 10:41
@tomfox0031 as suggested every time the update gets stuck, kill the app. You could also restart the phone/pc , then restart the download. Simply starting up the app should give a prompt to continue. You could also switch to a different device, it will continue from where it left off.
11-29-2016 16:27
11-29-2016 16:27
what did you do to resolve this? My fitbit wont do anything! just sits at the set up screen, im going crazy
11-29-2016 16:53
11-29-2016 16:53
11-29-2016 16:53
11-29-2016 16:53
Also restart your phone
12-01-2016 15:25
12-01-2016 15:25
Welcome to the Community @pontiac1624! I've noticed that most of the times where users are having issues with firmware update, it's because they are doing it from a mobile device. I would like you to try once again but this time using your computer.
Thanks for the great tips provided @Clobberin!
Hope this helps. Keep me posted.
12-24-2016 15:21
12-24-2016 15:21
12-27-2016 13:37
12-27-2016 13:37
Thanks for being part of the Community @Lyz123! Can you please confirm that you did this procedure in order to get your Blaze set up in your account and with the latest firmware version?
Hope this helps!
