Hi, Ive had my Blaze for one week, and must say i'm very disappointed.
Yesterday (24th January 2017) I used the cross trainer and set for 5miles ( my normal exercise). I set the Blaze to elliptical and started. at the end of the exercise and checking my dashboard i had the following results.
Yes the device recorded twice! as it must have automatically recorded the exercise as a run, because all thos ereadings are correct, with the elliptical low on steps and miles!
So today (25th January 2017). again set the machine to 5 miles, but today did not set the blaze to anything assuming it would auto record as a run! These are the results that appera on the dashboard
The blaze today recordede automatically as ellipical which is correct but again the steps are approx half and no distance.
Am I doing something wrong or is this a soptware issue ??? any ideas
It's great to welcome you @Huw53 and thanks for the information provided. I would like to know if you keep having inconveniences with your exercises, have you tried to use the SmartTrack feature to record your exercises? If you haven't, I recommend trying this since it will automatically register your exercises and log them to your account.
Try it and let me know the outcome. ![]()
