11-29-2018
11:18
07:43
AlejandraFitbit
11-29-2018
11:18
07:43
AlejandraFitbit
My Blaze left button will not work. I have to double tap to get the Blaze to show time and then swipe for any of the other functions. I have tried to clean the button with a toothpick as was instructed but did not work. I used a can of air spray and that did not help. I have tried re-setting and that did not work. Any suggestions?
11-29-2018 13:21
11-29-2018 13:21
Welcome to the forums!
Sounds like you have done all you can. Contact support to see what your options are
Contact
http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
12-02-2018 07:45
12-02-2018 07:45
A warm welcome to the Community @Nolaboiler and @WendyB thanks for the input.
I appreciate all the efforts in trying to fix this issue. Upon checking with our support team, I was told that you followed our friend's recommendation and contacted them. I know they will be glad to help you out and provide you a solution.
Let me know if you need anything else.
