I just bought the Blaze, and needed to charge it in order to complete the set up process. I have tried charging the fitbit for over 3 hours in 2 different laptops, however the fitbit wont charge past 4 red bars. I have also tried reseting the fitbit with no change in results.
It's great to welcome you @SunsetRunner, thanks for troubleshooting this by yourself.
If your Blaze isn't charging, I recommend taking a look at this post and follow the instructions provided there. After those steps, test your tracker.
I hope this helps, let me know the outcome. ![]()
Hi,
Thank you for your help. It turns out the fitbit was faulty. I took it back to the store i bought it from and they offered a replacement 🙂
You are welcome @SunsetRunner, I am glad to hear that you received a replacement. To set it up, you just need to do the following from your Fitbit app:
If you need anything else, do not hesitate in posting it.
Happy stepping! ![]()
