08-25-2016 01:15
08-25-2016 01:15
08-25-2016 01:56
08-25-2016 01:56
@AdrianReinboth i see your posting from an Android phone, so I'll start there.
For starters the app connects to the GPS, your Blaze connects to the notification app then the notifacation talks to the GPS.
First is your Blaze receiving notifacations? If not,
Swipe down on the phones notofacation panal, check for a message fitbit Notifacations are running.
You should be able to restart the phone and the GPS on the Blaze should connect, even without the fitbit app is running
08-25-2016 02:06
08-25-2016 02:06
08-25-2016 02:06
08-25-2016 02:06
11-20-2016 05:55
11-20-2016 05:55
Welcome to the Community @AdrianReinboth and @Rich_Laue thanks for stopping by. I would like to know if you keep having problems with your connected GPS? If you do, please take into consideration the following requirements:
After verifying all the requirements, try using GPS again. If you're still having difficulty, try these troubleshooting steps:
I hope this helps, let me know the outcome.
01-19-2017 08:04
01-19-2017 08:04
I am experiencing the same problem but with a windows phone 10. I got to exercise>Bike and it will try and connect to my phone but say that it couldn't connect and asks me to go to fitbit app. I have checked all the settings advised above, location settings and background usage etc. But it still can not connect to my phone.
06-21-2017 10:42
06-21-2017 10:42
Alejandra, thank you for your troubleshooting steps. It finally started working after I rebooted my phone (Samsung Galaxy Note 4).
06-22-2017
04:22
10:34
06-22-2017
04:22
10:34
09-25-2017 11:26
09-25-2017 11:26
Hello Alejandra,
unfortunately my Fitbit is still not connecting to my phone. I have an iPhone 7 fully updated. I have checked all my settings. Bluetooth and gps and notifications are all on. But still no luck.
09-26-2017 18:45
09-26-2017 18:45
I have the same issue and the broken back button too.
11-06-2017 07:11
11-06-2017 07:11
I have that problem too with my iphone 7+. I've been battling that since i've bought the Blaze. Something that i've recently noticed was that everytime my Blaze is out of range of my iphone, it obviously loses bluetooth connection but once you're back in range, it doesn't reestablish a connection with the FitBit app. So lately, I just have to resync my Blaze with the app then i'm good to go. I would also suggest to go through your Location Services Privacy settings and check to see how many apps are "Always" using GPS/Your Location. I have noticed that after editing permissions for some apps, i get a more consistent signal.
02-24-2018 06:43
02-24-2018 06:43
Hello I have tried everything listed to get my blaze use my Samsung S8 GPS to map my runs. It keeps telling me phone not found even when I'll get text message alerts. This is very annoying, it's the reason I bought the Blaze.
Is there anyway to correct this?
02-24-2018 07:16
02-24-2018 07:16
Hello @SunsetRunner do you have Fitbit notifications enabled or the Fitbit app loaded into memory? It does not have to be running in the foreground.
Also try a restart of the phone, I find before the phone completely restarts gps is connected.
Also swiping unneeded apps out of memory I have pc dishonor found us full.
02-25-2018 04:59
02-25-2018 04:59
Thank you but, yes I have restarted the phone. Yes I've closed so other apps and I have notifications on and added the Blaze as a trusted devise. Still nothing. I am ready to buy a Garmin
04-07-2018 12:55
04-07-2018 12:55
I have exactly the same problem that I can’t get my blaze to connect to the gps on my new phone (huawei mate 10 pro). I’ve read that there have been some syncing issues with these phones but I have no problem syncing the data, just can’t map a run without the gps connection.
I have tried all of the advice in your post but still no joy with this.
Run mapping is something that I want to use regularly and if I can’t make this work I will have to look for a different watch, very frustrating.
Please advise
Thanks
04-07-2018 19:20
04-07-2018 19:20
I too am having the same problems with my Blaze GPS not connecting to my iPhone 6. It would do this periodically and now for the last week it refuses to connect. I’ve been using Fitbit products for the last two years and have had numerous syncing issues. I am at the point that I am seriously looking at replacing my Blaze with a Garmin.
04-08-2018 03:40
04-08-2018 03:40
04-08-2018 10:48
04-08-2018 10:48
I have a Samsung Galaxy Note 4 and the Blaze. I've realized I can't be in a hurry for the Blaze to do anything when it attempts to communicate with my phone. I only turn Bluetooth on when I want the Blaze to use my phone's GPS for bicycling. First, I turn Bluetooth on (on my phone), then I select the Blaze when the Bluetooth dialog comes up. That never seems to accomplish anything, but I do it anyway. I also turn on the GPS option on my phone. Then I start the Fitbit app on my phone, leaving the phone and watch within a couple of feet of each other. Next, I do something else for about five or ten minutes to give the Blaze an inordinate amount of time to finally connect to my phone. That seems to do the trick for me. By then, I can choose the bicycling exercise option on the Blaze and it connects to my phone's GPS and off I go. When I've finished my ride, I sync the Blaze with my Fitbit app, which can take several tries. I end the Fitbit app, turn off GPS and Bluetooth and I'm done.
04-08-2018 14:33 - edited 04-09-2018 01:24
@JG_FB first I would stop selecting Blaze, this connection is established by the app not the user. After turning the Bluetooth on, you will need to wait for the app to realize that the Bluetooth has been turned on and connects the tracker. Now the request to use the Bluetooth may be sent from the tracker, and the wait to get a GPS lock on the satellites can now start.
If Bluetooth needs to be turned off throughout the day. for some reason. I would turn it on start the GPS on the Blaze, then restart the phone .The restarting of the phone should force the app to reach out and connect the Blaze
07-25-2018 11:37
07-25-2018 11:37
I have the same problem with my Samsung Galaxy S8 and Fitbit Blaze. I spend 5-10 minutes before each run or bike ride just trying to get the Blaze to connect. I have the app open and the Blaze literally touching my phone, I can see my steps syncing to my phone, but the blaze won't connect GPS. I restart my phone, bluetooth and even the blaze but no luck. Imagine doing that everytime you want to run. Sometimes, about one out of ten times, it connects. However, it disconnects and reconnects during my run, vibrating each time. This is very distracting. My phone is usually in my pocket or in a case around my arm, 2-3 feet maximum from my wrist. I never had this problem when I used the Samsung gear fit. Very inconvenient.
