09-25-2017
15:29
05:15
AlejandraFitbit
09-25-2017
15:29
05:15
AlejandraFitbit
My blaze will not hold a charge more than a few hours. I've cleaned both the Fitbit and the charging pad, reset it, used different charging blocks and still having the same issue. Please help
Best Answer09-25-2017 20:49
09-25-2017 20:49
Have you tried a different USB port?
See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
https://community.fitbit.com/t5/Charge/Fitbit-charge-battery-problems/m-p/1323307#M53291
http://help.fitbit.com/articles/en_US/Help_article/1799
If that does not help contact support
http://help.fitbit.com/?cu=1
Wendy | CA | Moto G6 Android
Best Answer09-26-2017 05:16
09-26-2017 05:16
Welcome to the Forums @RaevynDee, thanks for troubleshooting this by yourself and @WendyB for stopping by.
I would like to know if the instructions provided by our friend worked? If you still having issues with your battery, I recommend taking a look at this post and follow the instructions provided there. After these steps, test your Blaze.
Let me know the outcome. ![]()
