03-19-2016 19:00
03-19-2016 19:00
03-19-2017 17:45
03-19-2017 17:45
@Lillian_this depends on how new your Mac is, the newer ones don't need a dongle.
Have you tried turning your Mac off then power up?
Also if you have your phone with you their is no advantage in syncing through The Mac. The website doesn't care how the sync gets to the server
Best Answer03-19-2017 19:13
03-19-2017 19:13
Best Answer03-19-2017 19:19
03-19-2017 19:19
Best Answer03-20-2017 00:46
05-01-2017 16:36
05-01-2017 16:36
I was finally able to sync my Blaze with my 2015 MacBook Pro using the Fitbit Connect App. It worked as soon as I turned off the Bluetooth to my iPhone! I guess it was confused with 2 devices close to it.
Best Answer10-12-2017 03:33
10-12-2017 03:33
Try the solution found in this link ( https://www.howtoisolve.com/alternate-way-to-solve-error-bluetooth-not-available-on-mac-solved/ ) hope it works for you. Good luck.
