01-29-2016 08:38
01-29-2016 08:38
04-20-2016 00:04
04-20-2016 00:04
Hi @raheeljoseph81 welcome to fitbit
How are you trying to do the pairing? Fitbits are unusual in that they need to be paired via the fitbit app rather than the phone's bluetooth settings. This article has some guidelines that will hopefully help:
Best Answer04-20-2016 05:24
04-20-2016 05:24
Best Answer05-12-2016 11:31
05-12-2016 11:31
I am trying to set up my blze but still have the setup screen. what do I do next
Best Answer05-12-2016 12:28
05-12-2016 12:28
Best Answer05-12-2016 19:51
05-12-2016 19:51
Best Answer05-13-2016 08:10
05-13-2016 08:10
Best Answer06-19-2016 16:54
06-19-2016 16:54
I have a fitbit blaze, trying to do set up, on my computer it went as far as the update mode, shows connected by bluetooth. Won't go past that step. blaze still shows setup screen. Tried to set up on iphone 5. shows connected by bluetooth but when i go to the meet your blaze screen shows to be searching, then screen goes to "not working". ive tried all three suggestions. No matter what I do, I can't go past this step. Blaze still shows setup screen.
Best Answer06-29-2016 01:36
06-29-2016 01:36
My new fitbit blaze won't sync to my computer and all the screen shows is the fitbit icon and says fitbit.com/setup. What do i do
Best Answer06-29-2016 10:35
06-29-2016 10:35
Howdy do...I purchased a BLaze and have the same issue as Rashmi...The Blaze device still indicates setup. Any help will be greatly appreciated.
Best Answer06-29-2016 12:10
06-29-2016 12:10
@ImMarie ok, but may we know what device your using to set the Blaze up with?
Also at what step does it fail?
I cant find the post you are refferring to.
Best Answer06-29-2016 13:24
07-20-2016 05:23
07-20-2016 05:23
Just receive a brand new Fitbit blaze but the clock face only show fitbit.com/setup. So how to proceed. I have tried to reset but nothing happend.
Best Answer07-20-2016 05:38
07-20-2016 05:38
Best Answer07-24-2016 23:01
07-24-2016 23:01
Same here!! I never got my screen to change from fitbit.com/setup. Returning it in the morning and done with fitbit and the whole craze. I'll just keep using the apps on my phone.
Best Answer07-25-2016 06:03
07-25-2016 06:03
Best Answer11-20-2016 22:21
11-20-2016 22:21
New fit bit blaze still showing "could not complete update". Using windows ten, I have unindastalled and installed the app so i know it is the latest version, then i have blaze plugged i via dongle and have gone through all stages right from the begining and still getting the same message.
Any help?
Best Answer12-25-2016 10:05
12-25-2016 10:05
I'M HAVING TROUBLE WITH MY FITBIT. IT WON'T CONNECT TO MY PHONE.
Best Answer12-25-2016 10:13
12-25-2016 10:13
Hi @JRDS are you having trouble setting up your Blaze or was it working but has now stopped?
If you are having trouble setting it up then there is some guidance in this hep file:
https://help.fitbit.com/articles/en_US/Help_article/1873/
If that doesn't help then let us have some information and we'll try to help.
Best Answer12-25-2016 10:21
12-25-2016 10:21
Best Answer12-28-2016 17:18
12-28-2016 17:18
Trying to setup Fitbit blaze and it is stuck on the page where you put in the code......been spinning forever. What do I do?
