06-11-2017
18:08
06:34
AlejandraFitbit
06-11-2017
18:08
06:34
AlejandraFitbit
Does anyone else have issues with the Blaze? I had a Charge HR that broke over time and I expected equal or better results from the Blaze. This is not the case. Here of some of my issues:
- Does not sync properly as the data for the day on my Blaze sites not match what gets uploaded to my account
- Does not log naps even with sleep sensitivity turned up
- Often does not log steps while in run/walk/hike exercise mode
- Poor battery life as I need to charge it every other day
- Doesn't interface completely with the Galaxy S8 (had the above issues with my S6 as well). This problem should be fixed if Fitbit gets a firmware release to make the S8 compatible ... But still waiting on that.
Honestly wishing I would have saved the $ and just gone with a warranty replacement in the Charge HR. Anyone else seen the above issues and have fixes?
Best Answer06-12-2017 06:40
06-12-2017 06:40
It's great to welcome you @nononononon. Regarding to the issues your are having with your Blaze, take a look at the following:
Catch you later. ![]()
Best Answer06-12-2017 17:51
06-12-2017 17:51
Best Answer06-14-2017 04:07
06-14-2017 04:07
Thanks for the information @nononononon.
See you around. ![]()
