04-28-2016 22:09
04-28-2016 22:09
Best Answer04-29-2016 05:17
04-29-2016 05:17
Welcome to the Community @Bardees. If you are having problems setting up your Blaze, I recommend Restarting your tracker a couple of times more, after the restart process do the Setup Procedure from a computer this time.
I hope this helps, let me know the outcome. ![]()
Best Answer04-29-2016 06:26 - edited 07-16-2016 08:04
May I add that some have reported that leaving the Blaze in its charger and charging has help for the update to load.
07-13-2016 00:42
07-13-2016 00:42
I have the same problem how did you solve it?
Best Answer07-13-2016 04:29
07-13-2016 04:29
A warm welcome to the Forums @suejcotten. Have you tried the troubleshoot provided in the previous post? If you haven't, I recommend following it. After those steps your Blaze should work properly.
Let me know the outcome. ![]()
04:37
18:31
LucyAP
07-13-2016
04:37
18:31
LucyAP
Thank you. My husband took over the set up and managed to get it to
work!
Moderator edit: personal information and format
07-13-2016 04:46
07-13-2016 04:46
You are welcome @suejcotten and those are great news! I am glad to hear that your Blaze is now working. If you need anything else, do not hesitate in posting it.
Happy stepping! ![]()
