11-28-2017 22:45
11-28-2017 22:45
This has been the subject of numerous threads, but there's always an eerie silence from the administrators about this specific issue, so I'm checking to see if the problem has actually been solved. Bluetooth (Classic) won't pair with my Droid Turbo 2 for music control. The phone says it can't pair because of an incorrect PIN or passkey. Neither the Blaze nor the phone display a PIN or code, the phone just stops the pairing process and gives me the error message. I am NOT trying to sync the tracker with the low energy bluetooth. The tracker and my phone are synced and it actually did display a PIN while doing that through the Fitbit app. This problem is just when attempting to pair Bluetooth (Classic) for music control through the bluetooth settings menu on my phone. The tracker is set to pair, and it is showing up as a bluetooth device on my phone. It just isn't pairing or showing a pin/passkey to enter or accept. I have restarted and reinstalled the app, the phone, and the tracker. I have stood on one foot while rubbing my belly any patting my head and singing Abbey Road backwards. I swear to god if one of you tells me I'm probably trying to sync the tracker, that bluetooth classic is only for music control, or that I need to to this through the bluetooth settings menu I am going to return the thing with a long rant about how terrible this product is. Please help. Thanks.
07-31-2019 11:13
07-31-2019 11:13
07-31-2019 18:29
07-31-2019 18:29
The best course then would be to reach out to them @Catoutdoors.
They are the party that setup and maintains the connection to Fitbit.
08-01-2019 15:25
08-01-2019 15:25
08-02-2019 07:14
08-02-2019 07:14
If you are having an issue with MFP or Endomondo. The only thing Fitbit can suggest is to revoke access and then reconnect. If this has already been tried, then you will need to contact MFP or Endomondo. They are responsible for their Fitbit connection.
08-02-2019 09:52
08-02-2019 09:52
08-02-2019 09:55
08-02-2019 09:55
Has MFP or Endomondo got back to you?
09-04-2019
05:11
15:49
JuanFitbit
09-04-2019
05:11
15:49
JuanFitbit
You are really not answering the question of that people I am experienced the same problem and I am using the fitbit app.
Moderator edit: word choice
09-04-2019 08:07 - edited 09-04-2019 08:10
Sorry @claudiarosu may I ask which of the two completely separate issues mentioned in this thread are you having an issue with?
The main subject of this thread is about connecting the Blaze Classic Bluetooth to the an Android phone so that the user may control the music on the phone from their wrist. Are you having a problem controlling music on your phone from the Blaze?
This thread was then hijacked when a user mentioned a problem between their Fitbit account and a third party app. This has absolutely nothing to do with Bluetooth Classic or the Fitbit app. If your experiancing a sync issue between your Fitbit account and say MFP, the solution has been mentioned several times above. You must reach out and contact MFP, they are in control of this sync, Fitbit can do nothing to fix this.
As for your comment about the app, there has never been a post in this thread from a Fitbit employee, let alone a Fitbit developer.
BTW neither of the two issues mentioned in this thread have anything to do with the Fitbit App on your phone.
09-04-2019 12:50
09-04-2019 12:50
Lol Rich_Laue I have looked back and you're correct in saying I hijacked this thread.
I hadn't realised I'd done that !!!
I just seen 'problems with bluetooth and fitbit' and jumped in there thinking someone may be able to help which you kindly did.
Never mind at least its kept the thread going. Thanks for your help with the issue although I still can't connect my fitness pal to the fitbit. I can connect my fitness to endmondo and endmondo to fitbit but not my fitness to fitbit.
I think I'll take to wearing a mask and carrying a pistol and go out and rob a few banks lol That's a joke by the way 😁
09-05-2019 09:50
09-05-2019 09:50
As for Endomondo and MFP there is only one thing we as Fitbit users or Fitbit support can suggest. That is to revoke and then set it up again. This setup is done through Endomondo or MFP.
They are the parties that setup the link to Fitbit, they are the ones that handle and maintain this link.
If you are still having issues then they are the ones you will need to reach out to. There is absolutely nothing else that Fitbit Support, or Fitbit users can recommend to help you.
You will need to contact MFP and Endomondo.
01-11-2020 14:48
01-11-2020 14:48
I'm having the same problem and followed all the steps. Unsure what else to do now. I'm doing this for someone who has a learning disability and feel that they have wasted their money.
01-31-2020 17:27
01-31-2020 17:27
Adjusting my Android power/battery settings so that my Fitbit was not optimized and completing a pending Android update fixed my setup issues and my sink issues. YouTube it several people have made videos.
02-01-2020 00:35 - edited 02-01-2020 00:39
Sorry @Jellykat since this thread is now about 4 - 5 different unrelated subjects. You will need to be more specific than I have the same issue, which issue is that?
Subjects in this thread
05-22-2020 14:28
05-22-2020 14:28
So no one has a solution to this problem?????
10-03-2022 09:16
10-03-2022 09:16
Worked great. Automatically deleted the old and installed it again.
