Bluetooth missing from blaze settings
So i've got update 2.78 on the app and version number 17.8.402.1 on my blaze. Sometimes the bluetooth itself is missing on the settings section. Usually between brightness and heart rate. It comes and goes. Any thoughts? And yes ive done resets.
5 REPLIES 5
Welcome to the  Forums  @Gen085.
Thanks for sharing all the information on what versions you are running and for trying to reset before getting in touch with us.
I'll be moving this thread to the Blaze board as I think it is better suited for it.
Could you share some pictures of how it is showing up and then post them here as a reply? Both with the Bluetooth there and without. That should help us determine the best way to move forward.
Feel free to reach out with any questions.
Lanuza | Community Moderator
Remember to vote for posts that helped you out! Tired of the same workout music? Try a Podcast! 🙂
The top photo is after the reset. But I don not know how long it lasts then
it disappears after awhile.
Thank you
Hello @Gen085.
I'm afraid the photos didn't come through. Could you try to post it again directly on the Forums? Be sure to do so while typing your answer in the Forums by clicking on the 'Photos' button. Check the picture below for reference.
Let me know if you have any further questions.
It show up after reset, but then it would disappear. So far it has stayed since. maybe a total of 3 resets total.
Hello @Gen085.
Thanks for the pictures and for letting me know.
I have reached out to our support team and they should be getting in touch with you in regards to this. Please keep an eye on the inbox of the email that is connected to your Fitbit account.
