01-06-2016 10:39
01-06-2016 10:39
I see that GPS is not included in the new Blaze but that it can have have "Connected GPS" in conjunction with the FitBit App. Could someone please describe this process and how it impacts the recorded data? I currently have a Charge HR and if I active the GPS tracker on the App, none of the steps that I take during that exercise count in my challenges as they could be "erroneous data." As much as I'm interested in a Blaze, the ability to GPS track my runs will make or break my purchase decision. (If my tracked runs don't count in challenges, then the data is inaccurate and unacceptable.)
01-12-2016 14:47 - edited 01-12-2016 14:49
@Forestija@Rich_Laue@Michael To clarify, the Blaze does not currently include FitStar Yoga. We started with FitStar Personal Trainer workouts and may explore including FitStar Yoga workouts in the future.
One of the reasons for not including a built-in GPS chip is as we already have a product with built-in GPS, the Surge. In addition, you can check out some of my other key points in my recent post, here. Hope this helps in making your buying decision.
01-14-2016 10:28 - edited 01-14-2016 10:39
So if I get the Blaze it will still record my steps and distance just not the GPS route?? ( I do not want to have to carry my phone with me so a little confused as to what the best option is. I currently have the FLEX and looking to move to one product that I could use as a tracker and a watch. When I go to theme parks it doesnt seem to track all of my steps would that be different if I had the surge that would also use the GPS?
01-14-2016 11:54
01-14-2016 11:54
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
01-14-2016 12:38
01-14-2016 12:38
@ErickFitbit wrote:@Forestija@Rich_Laue@Michael To clarify, the Blaze does not currently include FitStar Yoga. We started with FitStar Personal Trainer workouts and may explore including FitStar Yoga workouts in the future.
@ErickFitbit Just to clarify a little bit, I understand that the Blaze comes with 3 FitStar workouts, but if you have a FitStar account can you load other workouts on the Blaze or are you limited to the 3 pre-loaded ones?
01-14-2016 15:09
01-14-2016 15:09
01-14-2016 15:32
01-14-2016 15:32
@ross_t wrote:
Blaze=no gps no thanks
Fair enough...
Mike | London, UK
01-14-2016 16:09
01-14-2016 16:09
That's something we're working on getting more information for. We'll check in with the approrpiate teams and get back to yall! @Michael
01-14-2016 16:52
01-14-2016 16:52
The Blaze will only record GPS if you have your phone with you and have MobileRun on. Otherwise it will just do step count, distance etc. The Surge on the other hand has GPS built in and doesn't require a phone until you want to sync and look at the data.
GPS has no affect on step count.
01-14-2016 16:59
01-14-2016 16:59
@matt9013 You are mostly correct, but you won't need to touch your phone or start MobileRun get GPS tracking on the Blaze. But like you said you have to have a compatible phone on you. (You just enable Connected GPS on the Blaze and when you start a run on the Blaze it will work just like the Surge, other than the GPS data comes from your phone instead of an internal GPS chip.)
01-14-2016 17:55
01-14-2016 17:55
Cool, I didn't know you could do it right from the Blaze. I thought you needed to start it from the phones app.
01-15-2016 01:45
01-15-2016 01:45
Mike | London, UK
01-15-2016 02:29
01-15-2016 02:29
I was wondering exactly that!
01-16-2016 10:20
01-16-2016 10:20
01-16-2016 16:08
01-16-2016 16:08
As probably already mentioned (or inferred), the amount of hardware they squeeze into these things impacts battery life and size.. I recall that when the Surge was first released a lot of folk were askling why it didn't have a full color screen, right? Well, the answer to that is color screen = greater power requirement.
Perhaps the ideal device would include a GPS AND a color screen. The trade-off though would mean that it would need to be much bulkier to accomodate that additional GPS hardware (transceiver) and a much larger battery to accomodate the color screen and GPS (OR alternatively a smaller battery but you would then have a device that needs to be charged daily..)
Battery tech will catch up.. But it's gonna take a few years. Until then, it's always a compromise between form and function 🙂
01-16-2016 16:14
01-16-2016 16:14
Exactly, a GPS built in would lower the battery life and same with touch color screen. IMO connected GPS is the best of both worlds. We still get GPS and the Blaze has a good battery life.
I know some people don't like to run with phones but I can't see not doing it. I mean what happens in emergencies, accidents, someone needs you ASAP etc. Not having a phone just doesn't seem safe IMO whether you don't like or not.
01-28-2016 12:09 - edited 01-28-2016 12:10
I would want GPS in Blaze,just like in Surge. In fact I would worry more about my phone battery dying because of GPS use (in case you need help). So I've started looking at https://buy.garmin.com/en-US/US/wearabletech/fenix-3-hr/prod545480.html as an upgrade from my current FitBit Surge..
01-28-2016
14:06
11:54
ErickFitbit
01-28-2016
14:06
11:54
ErickFitbit
I almost didn't even look at the features before preordering. What no GPS? You want me to carry my phone? Nope! The blaze looks pretty
Moderator edit: format
01-28-2016 15:09 - edited 01-28-2016 21:18
01-28-2016 15:35
01-28-2016 15:35
01-28-2016 16:06
01-28-2016 16:06
