04-13-2018
12:30
04:14
AlvaroFitbit
04-13-2018
12:30
04:14
AlvaroFitbit
My Blaze 2 is completely 'dead'. This happened during the night. There are no flashing green lights on the back and no response when I put it on charge. Any ideas?
04-13-2018
20:02
04:15
AlvaroFitbit
04-13-2018
20:02
04:15
AlvaroFitbit
Can you do a Restart when plugged in?
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
If not Contact Support.
http://help.fitbit.com/?cu=1
Wendy | CA | Moto G6 Android
04-15-2018 04:29
04-15-2018 04:29
@Petticoat Welcome! Thanks for being part of our Community! You can try cleaning the tracker's contacts with a toothpick or toothbrush and then use cotton with rubbing alcohol. After this try charging your tracker by plugging it for a couple of hours directly to your computer's usb port or use an UL listed usb wall adapter. Finally try the restart @WendyB suggested.
Let me know how it goes!
