@Cbrust Yeah that's pretty unusual. I'd say reach out to Customer Support and provide those details, they should be able to help you out. 🙂
A couple things i can think off.
Turn off all auto detected exercises that you don't do.
You migh also want to turn off always connected.
Best AnswerDid anyone get any help with this issue? I got mine a week ago and started having this issue. It wouldn't even last a full day. Very frustrating. Any advise/help appreciated.
Best Answer@Cbrust the resolution is to follow @AndrewFitbit's advice above.
Sorry @esskay123 the Bluetooth to sync with can not be turned off.
Hi All,
Found the solution to this issue... It's not only about turning off Bluetooth and other unwanted services, but most importantly ensure you backup your Blaze with your phone... If there's too much data on the Blaze, this is leading to battery drain as well, not sure why (data making the device heavy?.. hehehe) but this is THE solution for it... Now I charge once in 3-4 days even with constant use. When my device was "heavy" it needed me to charge it daily! Hope this helps...
The Schwarzenegger
