04-13-2017 06:48
04-13-2017 06:48
I received my Fitbit Blaze during early March. The battery life last for 5 days but after 2 weeks of usage the battery life drop drastically and it only last for 8 hours now. It is normal?
Best Answer04-13-2017 10:35
04-13-2017 10:35
Welcome to the forums!
Please clean the contacts
http://help.fitbit.com/articles/en_US/Help_article/My-tracker-s-battery-isn-t-charging/?q=not+chargi...
Then Do a Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
If it doesn't help Contact Support
http://help.fitbit.com/?cu=1
Look around the forums and join in on some of the discussions! Lot's going on!
Hope to see you around!
Wendy | CA | Moto G6 Android
Best Answer04-13-2017 10:37
04-13-2017 10:37
A lot of people reported this issue after the last firmware update.
Have a look at this discussion:
https://community.fitbit.com/t5/Blaze/Blaze-battery-draining-after-update/td-p/1927978
Best Answer04-13-2017 12:10
04-13-2017 12:10
I have had the same problem they do nothing about it I just charge it every day when I am in the shower. They know the battery life because every time you charge they get the data
04-13-2017 22:09
04-13-2017 22:09
Best Answer04-14-2017 04:23
04-14-2017 04:23
I have the same problem, usually last between 24 hours and 36 hours
05:56
07:09
04-14-2017
05:56
07:09
Hello all, I hope you are doing fine! ![]()
If you are having problems with your Blaze battery life, I recommend taking a look and follow the instructions provided in this post.
I hope this helps, let me know the outcome. ![]()
Best Answer04-14-2017 11:53
04-14-2017 11:53
The issue is constantly skirted by all at Fitbit. You have a major battery drain issue that you will not address.
04-14-2017 11:54
04-14-2017 11:54
Restating your blaze doesn't help the battery charge. Ever
04:11
07:09
04-17-2017
04:11
07:09
Thanks for the information @Trinity---. At this point, I recommend keeping an eye to your inbox for further instructions.
See you around. ![]()
