11-17-2019 23:32
11-17-2019 23:32
My Fitbit blaze will not charge. I have tried everything over the past two days - cleaning the points, using different USB chargers, using different USB points and resetting (multiple times) but all to no avail. It’s three years old (March 2016) but to say I am
disappointed is an understatement. Any help?
11-29-2019 22:30
11-29-2019 22:30
It’s very frustrating. I spent a lot of money buying the ‘special edition’ 3 years ago. Further the thick band gave me a carpal tunnel syndrome so I had to buy a thinner band, and I also bought a leather one for other occasions. Now they are all useless, totalling nearly £400!
I got a token but the majority of discount was for two horrid colours that they clearly want to get rid of, and the actual watch I want is not valid at all for the coupon.
My daughter’s 4 year old Apple Watch is still going strong, and although she needs to charge at night it’s much more cost effective. I am hugely disappointed, and it seems from this thread that many of us at 3 years are seeing planned obsolescence.
I wont buy again, and will stop recommending this product to my friends.
12-01-2019 17:56
12-01-2019 17:56
12-01-2019 23:51
12-01-2019 23:51
That’s great for you. Thanks for sharing. Where did you get the new battery from? I was not offered this? Is your model a Fitbit blaze and how old is it? Thanks.
12-02-2019 11:00
12-02-2019 11:00
How do you get a new battery??
12-02-2019 11:42
12-02-2019 11:42
12-03-2019 01:28
12-03-2019 01:28
That was very nice of them. It looks like you are a special case though, as reading through the comments it looks like no one else got a new battery. I’d be prepared to buy one I don’t need it free, it’s just I spent such a lot of money on different wristbands too and got a special edition. Plus more eco friendly to replace battery rather than buy a new watch. I’ll email and ask. Best wishes, Jill
12-03-2019 13:35
12-03-2019 13:35
Re new battery. I spoke with customer services. The blaze does not have the ability to change batteries. Only a model called ‘zip’ which is now out of production, and also they have told me they do not have any technical services. So those of us on the blog with a Blaze are out of luck.
12-03-2019 14:48
12-03-2019 14:48
12-03-2019 14:54
12-03-2019 14:54
So the Blaze is a throw away watch huh? I don't think I'll be buying another one.
12-03-2019 21:03
12-03-2019 21:03
So, as a completely unaffiliated electronics technician... the battery should be able to be replaced by the removal of the 4 screws on the back and finding a battery of the same kind that is in there. I doubt they had a specialized form factor made for their product, so it should be an off-the-shelf type and size. Though likely not something carried by most jewelers.
Other things that might help, clean the contacts on the back of the watch itself with a high (905) rubbing alcohol, also try cleaning out the holes in the center with a needle. Try to lightly clean the pins in the charger the same way.
12-04-2019 06:55
12-04-2019 06:55
12-04-2019 14:08
12-04-2019 14:08
Thank you. I will try these suggestions. Down at my location we don't have access to such batteries or service shops
09-16-2020 09:15
09-16-2020 09:15
Did that
also use a huge binder clip
ridic
why can’t they fix this?
why do we have to jump thru hoops 2
get this thing 2 charge?!
