Heart rate sensor and battery issues
My Charge HR battery started to drain very fast approximately a week ago. A full charge lasted up to 4 hours only. At this time I also noticed the HR monitor also started to fail with either not reading or stuck at 70.
I noticed that one of the LED was not flashing but remained dimly lit. I have tried full reboots of the watch, turning the HR on/off and numerous syncing but all attempts have failed. The watch has expired on the 2 year warranty in May and I am led to believe from the Fitbit community that there are no repair centers for these.
It's a bit of a waste to just throw away a watch for what should be a straight forward repair for fitbit.
Let me know your recommendations on a way forward please if there are any.
4 REPLIES 4
@CraigD69
 Here are some ideas to increase your battery life
Increase your battery life
Try these ideas below if the above doesn't help.
Restart your FitBit
http://help.fitbit.com/articles/en_US/Help_article/1186
Restart your Fitbit Charge
https://m.youtube.com/watch?v=JPvdDoWGckM
Factory reset
https://help.fitbit.com/articles/en_US/Help_article/1606
 Community Council Member
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
>Contact
In this short video, we will go over the simple process of rebooting or restarting your fitbit Charge. You do this when the device is not responding. This won't erase any fitness activity. 1. Plug in the USB charging cable 2. PRESS & HOLD the button for 10 seconds, until you see the fitbit logo ...
Thanks for your response.
However,  I have mistakenly stated Charge HR  when it should be the Blaze HR which is my current watch I am having the issues with. (the charge was my old watch).
No problem, I'll move this post over to the blaze forum.
Cheers
>Contact
It's great to see you here @CraigD69 and @ACG thanks for stopping by.
The troubleshoot provided for the Blaze is almost the same. I recommend taking a look at the following links and follow the instructions there:
Let me know the outcome. Smiley Happy
