Not recording floors correctly
ANSWERED
Since the update my floors doesn’t appear to be recording correctly. I have taken to using the stairs rather than the lift since having the Blaze and it had always been reasonable in the calculations. However I know I have done 10 floors this morning and it’s only recorded 2. 😳
Anyone else noticed this or am I being to critical? 😢 But I think an 80% failure is a bit exceptional.
1 BEST ANSWER
Accepted Solutions
It's great to see you around @SilverPops, thanks for troubleshooting this by yourself.
If your Blaze isn't registering the number of floors correctly, I recommend restarting your tracker, put it on, find a location where you have 2 flights of stairs in a row (keep in mind that each one should be at least 10 feet tall), walk the stairs and let me know how many your tracker registered.
Hope to hear from you soon. Woman Happy
8 REPLIES 8
I've been having the same problem with my Blaze
Welcome to the Community @jjuby. I would like to know if you have take a look at my previous post? If you haven't, I recommend checking it and follow the instructions provided there.
Keep me posted about the result. Smiley Happy
Thank you so much for the help! It's now recording my floors again!
It's great to hear that @jjuby, I am glad to hear that your tracker is now working properly. If you need anything else, do not hesitate in posting it.
Happy stepping! Smiley Happy
@AlejandraFitbit
Yes thanks worked for me also.
appears to be recording similar to before now.
Those are great news @SilverPops! Having a tracker working properly is awesome. If there is anything else we can help you with, do not hesitate in posting it.
Keep the stepping up! Woman Wink
This is a solution but not optimal.I have to restart my Blaze repeatedly. It also doesn't fix or record the elevation gain in a hike to floors climbed. Just wondering, are you working on a solution?  This is one of the key features that made me choose Fitbit.
Please tell me Fitbit is working on a fix.
I also keep hoping badges will be added for total floors climbed, I maxed out in 2014.
