11-14-2017
06:25
07:04
AlejandraFitbit
11-14-2017
06:25
07:04
AlejandraFitbit
My Fitbit won't sync or get notifications of calls or texts.
Best Answer11-14-2017 06:46
11-14-2017 06:46
I would try restarting your phone and then restarting your fitbit using this procedure:
https://help.fitbit.com/articles/en_US/Help_article/1186/
Give this a few tries as it doesn't always work. If it still won't sync after that then there are some more ideas to try in this help file:
11-15-2017 07:07
11-15-2017 07:07
It's great to welcome you @Cyndi68!
Regarding the issues you are experiencing with your tracker, I recommend taking a look at the following links and follow the instructions provided there:
Also, please check that your tracker is paired. If it is not paired, do the following to set it up:
I hope this helps, let me know the outcome. ![]()
